94 f-150 death wabble
i bought a short bed frame from a junkyard and someone had already done a sas on the truck so i bought the front axle with it.... they had a 6 inch lift but did not buy radius arm drop brackets the just welded the original brackets to the frame...im guessing they just bought the 7 dagree c bushings...i had a 6 inch lift on my old truck and when i swaped the frame i used my drop brackets so it looks like the caster is way in the positive... i checked all the tie rods...ends.. trac bar mount bushings.. bearings.. ball joints..took the truck in for alignment they said the camber was good.. so i guess what i am asking is it possible to have to much positive camber...and is the what is causing my death wabble... it starts around 25 to 30 mph i will post pics tomarrow
TWDITMORE
04-18-2013 08:32 PM
jbirdsvt
03-06-2007 08:48 PM
95f150
05-13-2005 08:41 PM
