Steering Linkage
Old Feb 17, 2011 | 06:03 PM
gottagojoe's Avatar
gottagojoe
Steering Linkage
Is it really necessary to convert from a Y linkage to a T linkage on a 1977 F150 for a 6" Lift?
Old Feb 17, 2011 | 06:14 PM
1977F1504X4AUBURN's Avatar
1977F1504X4AUBURN
I would. You can't get a drop pitman arm for our year of truck.
Old Feb 17, 2011 | 07:32 PM
gottagojoe's Avatar
gottagojoe
Wallet has started on fire
Old Feb 17, 2011 | 09:02 PM
1977F1504X4AUBURN
Then stop spending. If your going to do it, do it right the first time. Jeff's Bronco Graveyard has an adjustable setup for $285.00 (recommended) or the non adjustable for $190.00. The key is patients. I would also recommend getting 7-degree offset C-bushings so your caster isn't messed up. Setting the caster helps your steering center itself while driving. If that's not right, you get bump steer and your truck want's to go wherever it wants when your over 50mph. I made all these mistakes and I only have a 4" lift and 35's.
wmring
Aug 30, 2024 09:29 PM
Burple
Dec 27, 2002 11:08 AM
Mike W
Jun 7, 2002 07:44 PM
Nathan
Feb 10, 2001 11:50 AM
jethro
Nov 25, 2000 08:21 AM
