LINKAGE ADJUSTMENT
Old Nov 15, 2002 | 01:23 AM
Burple's Avatar
Burple
LINKAGE ADJUSTMENT
Old Dec 27, 2002 | 07:17 AM
boardwell's Avatar
boardwell
LINKAGE ADJUSTMENT
HELLO,
I HAVE A 88 F-150 4X4 5-SPEED, NOW WHEN I BOUGHT IT, IT HAD A LEAKING TRANSMISSION, BUT ONLY WHEN THE TRUCK WAS MOVING, SO I REALIZED WITH THE HELP OF SOME FORD ENTHUSEIST THAT IT WAS THE FREEZER PLUG LOOKING THINKS ON TOP/BACK OF THE TRANNY, SO I REMOVED THE STICK AND TORE UP THE CARPET, UNBOLTED THE INSPECTION PLATE, AND REMOVED THE TOP OF THE TRANNY TO TRY AND RTV THE PLUGS REAL GOOD TO STOP THE LEAK, NOW WHEN I WAS PUTTING THE TOP OF THE TRANNY WITH THE LINKAGE COMING OUT OF IT BACK IN TO IT'S SPOT I ACCIDENTLY MOVED THE LINKAGE A LITTLE, SO AFTER PUTING EVERYTHING BACK TOGETHER, THERE IS A VERY SMALL GRINDING SOUND IN 1ST AND 2ND GEAR. AND IT IS HARD TO GET INTO 1ST, NOW I PLAN TO GO BACK AND FIX IT, BUT I'VE HAD TO DRIVE THE TRUCK SEVERAL TIMES IN THE CONDITION IT IS IN, SO MY QUESTION IS...WHAT KIND OF DAMAGE AM I DOING TO THE TRUCK, IS THERE ANYWAY THAT I COULD LESSEN THE DAMAGE FOR NOW, UNTIL I CAN GET BACK IN THERE AND CORRECT THE ERROR? IS THERE ANY EASY METHODS OF ALIGNING THE LINKAGE WHEN I PUT IT ALL BACK AGAIN?
THANKS FOR ANYHELP
LUKE IN MN:-X12
Old Dec 27, 2002 | 11:08 AM
steve83's Avatar
steve83
LINKAGE ADJUSTMENT
IT'S HARD TO READ AND IS USED TO SIGNIFY YELLING OR EMPHASIS.
Isn't this a whole lot easier?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
