Dash help
Old Mar 12, 2003 | 09:07 AM
mcostnza's Avatar
mcostnza
Question Dash help
You know when you change gears on an automatic, the gear is pointed to on your dash? Well, that little line no longer points to the gear it is suppose to, it is stuck at the far end under 2!! No problems going into gear though, just have to count how many times over to get into the correct one.
I know I have to pull my dash apart, but how far to I have to go? Do I need to pull the stearing column apart too? Is the beyond the basic or a pretty simple job?
Thanks.
93 F250
460
4x
Old Mar 12, 2003 | 09:20 AM
pfogle's Avatar
pfogle
Dash help
sounds like your indicator actuator is loose, pull the cluster and it should be on the right side of the steering column, mine is white, it has a string coming out of it, the string may be snagging on something or may just have broke.
Old Mar 12, 2003 | 09:24 AM
mcostnza's Avatar
mcostnza
Dash help
Pull the cluster? As in the dash or instrument panel?
Thanks
Old Mar 12, 2003 | 09:32 AM
pfogle's Avatar
pfogle
Dash help
the instrument cluster or panel. you might look up under the dash and see if you can see the piece on the side of the streering column, the little bolt may have just fallen out.....
Old Mar 12, 2003 | 09:46 AM
mcostnza's Avatar
mcostnza
Dash help
thanks again.
Old Mar 12, 2003 | 09:23 PM
steve83's Avatar
steve83
Dash help
I'm betting either the cable broke, or the boss on the pointer that the cable loops onto broke off.
Either way, you have to pull the cluster out of the dash, and you have to pull the column shroud to unhook that end of the cable first.
Old Mar 18, 2003 | 02:12 PM
mcostnza's Avatar
mcostnza
Dash help
fixed the problem--a plastic piece holds the spring onto the steering column. Ford only sells the whole thing, spring, plastic and indicator --about 22 bucks. Not bad considering. Just replaced the piece though, why bother with the rest.
blueoval1988
May 1, 2010 08:56 AM
vader17
May 15, 2007 03:50 PM
rickv
1983 - 2012 Ranger & B-Series
Feb 10, 2004 01:18 PM
rayvin_
Feb 26, 2001 10:21 PM
