E4OD No Overdrive
Old Feb 17, 2011 | 12:18 AM
thewojoes's Avatar
thewojoes
E4OD No Overdrive
I have a Winnibago on a F550 Chassis 1990, I took it to the gas station today and the overdrive didn't work.
The last time I drove it, it worked fine.
I push the button and the light goes on and off but nothing happens; otherwise the rest of the transmission works fine.
Any ideas? I want to go on a 600 mile trip in two days but not without overdrive.
I'm hoping, some simple solinoid or something.
Old Feb 17, 2011 | 07:42 AM
subford's Avatar
subford
Hard to say but here is what the Shop Manual says:
No 3-4 upshift.
Possible Source(s):
Shift solenoid operation.
-- (S1 or S2 solenoid suspected).
Action(s) to Take:
Refer to «electrical diagnosis» procedure in this section. Service as required.
Possible Source(s):
Valve body bolts not tightened to specification.
Action(s) to Take:
Retighten bolts to the «specification» listed at the back of this section.
Possible Source(s):
3-4 shift valve and spring.
-- Valve stuck, nicked or damaged.
-- Spring missing or tangled.
Action(s) to Take:
Determine source of contamination or damage. Service as required.
Possible Source(s):
Overdrive accumulator regulator valve and spring.
Action(s) to Take:
Possible Source(s):
Overdrive clutch assembly.
-- Clutch plates burnt or worn.
-- Overdrive clutch cylinder damaged/feedbolt loose or missing/sealant leaking/seals damaged/misassembled/missing.
-- Cylinder ball check stuck or missing.
Action(s) to Take:
Dbl A
Apr 8, 2017 02:28 PM
MT-F250
41
Feb 27, 2013 02:34 PM
craziejoker
2004 - 2008 F150
Jun 29, 2010 09:48 PM
baxter17
1983 - 2012 Ranger & B-Series
Apr 29, 2010 09:44 AM
Joeymt3
Apr 25, 2010 03:54 PM
