Temperature Gauge
Old Dec 29, 2005 | 07:10 PM
4WD F-150's Avatar
4WD F-150
So thats where the little turd is, my temp guage on my 302 quit working so I replaced the sending unit on the front of the engine. The guage still didn't work so I thought the guage itself was bad, no one told me there was a second sending unit for the guage that is seperate from the computer one.
Old Dec 29, 2005 | 08:01 PM
MustangGT221's Avatar
MustangGT221
The computer sending unit/sensor is right at the thermostat for the best/optimal readings. The sending unit on a V-8 for the dash gauge is on the intake manifold behind the A/C condensor, it's on the right side vs left side and is a 1 wire hookup.
Take the wire off, and ground it. If the temp gauge needle pegs out than it's ok. This sending unit usually doesn't go bad - probably bad connection.
Old Jan 2, 2006 | 07:13 PM
canadian 94 ford's Avatar
canadian 94 ford
Do not worry about I have 94 4.9 and the temp gage has read the same since i bought the truck in 94 it only goes to the N in normal summer and winter
Old Jan 3, 2006 | 12:02 AM
smecomark1's Avatar
smecomark1
Thumbs up
Most temperture gauges are usually whats known as an "RTD" (Resistance Temperature Detector) they work on the principle that Electrical Resistance (Ohms) will change in proportion to a temperature change. So really what you are looking at on the actual gauge is a Voltage Drop Meter that is calibrated for temperature. If the gauge is not reading correctly consult your favorite Service Manual to find the circuit and ID the color(s) of the wires. Perform the following Electrical checks with the battery disconnected
1)Check for contiuity from fuse to gauge, gauge to RTD probe on the engine. If you do not have continuity between either component it indicates a bad wire in that section. The RTD can be checked out of the engine with a thermometer as a referance and a pan of hot water, check Ohms acrossed it cold and Record, heat it up and check it again, the value should INCREASE. If not replace the sensor.
Perform the following checks with the battery CONNECTED
2)Check source voltage at the gauge should be ~12v and record it,
3) With the aid of another person and a set of test jumpers check for voltage at the lead going to the RTD probe (wire should be off the probe) on the engine, you should see source voltage between the hi side of the gauge and the wire at the probe, you should see NO source voltage or very little (<1v) between the lo side of the gauge and the probe wire (STILL OFF PROBE).
With the wire ON the RTD probe check the voltage between the lo side of the gauge and the probe. This value should reflect the actual temperature so it will very. HI volts if its hot, Lo volts if its cold.
If the volts very according to temperature Change but the gauge does not reflect that change REPLACE THE GAUGE.
Hope this Helps
Mark J.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
