EVR Question
Old Jan 2, 2006 | 02:58 PM
painterman's Avatar
painterman
EVR Question
91 F-150, I-6 engine. I have in my hand part # FOTE-A1A 9J459. I believe its the EGR vacuum regulator, sometimes called Vacuum solenoid. Anyway, when i hook a vacuum tester to the bottom of the 2 vacuum connections, it makes a funny sound(like a fart) on the top of it and wont hold vacuum at all. Is this normal? Thanks so much. Frank
Old Jan 2, 2006 | 03:33 PM
handyman43358's Avatar
handyman43358
I'd guess that its messed up. It's supposed to hold a vaccuum through one tube, then when commanded by the computer, to send the vaccuum through the other line to open up the EGR valve. I'd say hit up a junk yard. My 91 ranger and 95 f150 have the same exact part that you're talking about.
Old Jan 3, 2006 | 07:05 AM
EPNCSU2006's Avatar
EPNCSU2006
I believe it is supposed to work that way. It vents the control line to the EGR valve in order to release the valve. If the other one holds vacuum, it's probably working correctly.
lizardman1
18
Aug 22, 2023 07:49 PM
62FE4x4
Jun 11, 2017 06:45 PM
npccpartsman
Sep 26, 2015 08:15 AM
johaner78
Aug 8, 2011 06:34 PM
KS324
Dec 21, 2008 09:36 PM
