351m-400m intake
Old 02-16-2011, 06:06 PM
rednex77's Avatar
rednex77
rednex77 is offline
351m-400m intake
Does anyone know if an intake from a 351m will fit onto a 400m? the 400 has a 2 barrel and i would like to switch it to a 4 barrel witch i have on a 351m.
Old 02-16-2011, 06:12 PM
NW 150's Avatar
NW 150
NW 150 is offline
it should i believe. same block
Old 02-16-2011, 06:17 PM
rednex77's Avatar
rednex77
rednex77 is offline
that would be awesome. i just got a 250 and i would like to give a little more with a 4 barrel. thanks alot, i appreciate it.
Old 02-16-2011, 06:29 PM
NW 150's Avatar
NW 150
NW 150 is offline
hey no prob. hope everything works out
Old 02-16-2011, 08:07 PM
79F150400M's Avatar
79F150400M
79F150400M is offline
Thats Affirmative....
they go together like peanut butter n jelly. My engine was a 351M....Now its a 400. One of the main reasons for not dropping a 429 in there was the fact I can re-use the intake, headers and all accessories on the 400 since externally they are the same. IIRC....my whole rebuild (circa 1996) cost me $1200. Had machine shop do all the work I couldn't do, and I re-assembled everything myself. Just wish I knew about that T.Meyer fella back then....I would have sprung for the flattop pistons.
Old 02-16-2011, 08:27 PM
boggin79ford's Avatar
boggin79ford
boggin79ford is offline
i have a used edelbrock 400 intake for sale if your interested pm me
Old 02-16-2011, 08:51 PM
joerickson's Avatar
joerickson
joerickson is offline
They are the same engine, only difference is pistons and crank. Everything that will bolt to the outside of a 351m will also bolt to a 400.
Old 02-18-2011, 10:11 PM
rednex77's Avatar
rednex77
rednex77 is offline
thats awesome. thanks alot guys. i cant tell you how much that helps me out. the cams should fit also then right?
Old 02-19-2011, 07:23 AM
NW 150's Avatar
NW 150
NW 150 is offline
should yep
Old 02-19-2011, 08:06 AM
Deluxetruck's Avatar
Deluxetruck
Deluxetruck is offline
I don't believe there were any factory available four barrel intakes for the 351m/400. Unless the intake on your 351m is aluminum, there is a good chance it's a not a 351m.
-Jared
Old 02-19-2011, 08:23 AM
ranger429's Avatar
ranger429
ranger429 is offline
The cams will swap but me personally I would not use an old cam in a different engine.
-Jared
There were no factory 4bl setups on the 351M or 400.
Old 02-22-2011, 09:57 PM
shamineaukyle's Avatar
shamineaukyle
shamineaukyle is offline
I amy be interested in the intake, which is it, price etc. Got a 400 and 351m I am working on dialing up a bit. Thanks Kyle
my email is kyle@shamineau.org
Old 02-23-2011, 02:51 PM
fair67driver's Avatar
fair67driver
fair67driver is offline
I just bought an Edelbrock aluminum four barrell intake (351m-400)that has 1,000 miles on it......for $40.00. Guy swapped in a 460 and no use for the intake anymore. Its good to have friends....
BigCountry1978
01-04-2016 09:37 PM
41505379
12-19-2015 08:12 PM
1979 300i6
WTB - Parts & other
09-28-2014 10:44 PM
Lawrence Taylor
13
07-07-2014 09:44 PM
screamin
12-03-2005 11:03 PM
Quick Reply: 351m-400m intake
