400 tune up blues
Old Dec 3, 2005 | 07:56 PM
screamin's Avatar
screamin
400 tune up blues
my truck is blowing black smoke out of the exhaust. I replaced the plugs, cap and rotor. It has a new carb. motor is a 351m converted to a 400, 4barrel holley 600 What is the correct timing for this. Help
Old Dec 3, 2005 | 07:58 PM
ford390gashog's Avatar
ford390gashog
well,
timing is not your problem thats for sure. you have a serious fuel issue a very bad one. how did you tunr the new holley?
Old Dec 3, 2005 | 08:01 PM
screamin's Avatar
screamin
I just got the new carb, haven't did any adjusting to it... what do you suggest
said it was flow test and pre-adjusted
Old Dec 3, 2005 | 08:08 PM
ford390gashog
holley should have given you a check list of stuff to do to it before even mounting it. you will need to adjust mixture screws,choke, and install a power valve to work with your enigne. take the vacuum of the engine divide by 2 and use a power valve with the same number.
Old Dec 3, 2005 | 08:09 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Dec 3, 2005 | 08:18 PM
screamin's Avatar
screamin
I guess I will need to get a vacuum gauge. The instuctions said adjustment are preset at the factory and should not need any adjusting, but it does explain how to adjust if needed... Looks like I will give it a try
Old Dec 3, 2005 | 11:03 PM
LxMan1's Avatar
LxMan1
The first thing I would check once you verify that the choke is opening is the float level. Look down the throttle bores at an idle and see if gas is dripping into them from the venturis. If so, then one of the floats is too high or has a piece of debris in the needle and seat.
Joel Cassell
WTB - Parts & other
Aug 23, 2016 03:35 PM
daddies77-400toy
May 5, 2012 06:26 PM
74shane
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Sep 17, 2005 01:26 PM
goosedawg
Jan 21, 2001 09:41 PM
rick
Nov 21, 1999 10:06 PM
