Block heater swapout?
Old Feb 16, 2011 | 01:19 PM
JJONES660's Avatar
JJONES660
Block heater is showing up today. I believe its actually an oil heater not a coolant heater...Is this correct? so question is which one is it and whats the easy procedure to do this. If oil can I just drain the 14 quarts and throw back in the top when done? My oil has less than 1000 miles on it...maybe not even 300 miles on it.
Thanks ahead of time...you FTE guys rock
Old Feb 16, 2011 | 01:47 PM
Robbgt's Avatar
Robbgt
FYI It's coolant. If you're quick, you may be able to swap and loose minimal coolant... just be prepared for a face full...otherwise if you're up for a coolant flush anyways, might as well drain it all
Old Feb 16, 2011 | 02:31 PM
JJONES660's Avatar
JJONES660
Okay coolant gotcha...does it plug into block or radiator. A dodge mechanic thought it was opposite but what does a cummins guy know LOL
Old Feb 16, 2011 | 02:45 PM
Robbgt's Avatar
Robbgt
This should help ya, couple pics here
https://www.ford-trucks.com/forums/9...-location.html
Old Feb 16, 2011 | 06:51 PM
JJONES660's Avatar
JJONES660
Those pics make it look like its going into the oil path???? Is there coolant in that same area as well?
Old Feb 16, 2011 | 06:56 PM
Ken_C's Avatar
Ken_C
its a coolant heater. drain the coolant then swap out the heater.
Old Feb 16, 2011 | 08:18 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
In this pic you can see they have different path (oil and coolant are separated, you can see the resistence of the block heather there).
Old Feb 16, 2011 | 09:30 PM
fordpride's Avatar
fordpride
The coolant runs in the the cooler around the oil path and cools the oil
Old Feb 17, 2011 | 12:08 PM
redman84's Avatar
redman84
Be careful if you're going to just try and do it quick because when you pull the plug it comes flying out with a vengeance. Don't ask how I know...
blueeyedfordguy
General Diesel Discussion
Dec 16, 2013 02:22 PM
FSJ-EARL
Jan 4, 2010 06:43 AM
horak8
Jan 23, 2009 07:52 PM
QUINCE
Nov 6, 2008 10:40 AM
Fordbronco69
18
Dec 24, 2004 06:20 AM
