Front bumper interchangability
Old Feb 15, 2011 | 02:47 PM
Thunderbird7480's Avatar
Thunderbird7480
I was wandering around Pull-A-Part today and saw a few potential front bumper replacements for my '77.
Just wanted to know if the front bumpers off the '80-'86 models are a direct fit? It looks pretty close just by eyeballing it.
I could tell that the '87 and up models would not work without modification.
Old Feb 15, 2011 | 03:16 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
73 to mid 77 (no license plate slit) will work with current front fender curve. 78-79 will maybe but might hit front fender and and grill shell at top curve of bumper.
I thing 80-86 has a different top edge curve and will not fit, but I am only using some old memory.
Best try a 78-79 (has slit for license plate) and space it fwd (1/4") to clear fender and grill.
Let us know what you get worked out w/pics.
Old Feb 15, 2011 | 03:57 PM
Thunderbird7480
Guess I need to do a little measuring. I was more concerned with it lining up with the frame, but now that you mention it there isnt much clearance between my current bumper and the fender/grill. The truck in particular is an early 80's model. The bumper is about all thats left of it.
Old Feb 15, 2011 | 04:09 PM
77&79F250's Avatar
77&79F250
The frame width/bumper mount holes should be the same, but the its the angle of the bumper that gets you trouble, where it bolts to the frame end.
Old Feb 15, 2011 | 04:27 PM
Thunderbird7480
Maybe possible to use shims to correct????
I dont know. clearly I am going to have to look into it more. I need to go back to pull-a-part for my fenders anyways, so I will check it out then.
Old Feb 15, 2011 | 04:52 PM
77&79F250's Avatar
77&79F250
Yes but not a big stack up, just enough to clear your fender/grill. I would just use a 77 in better shape or get a new one from a FTE sponsor.
I doubt you will be able to transfer your bumper guards , if you are planning to?
Old Feb 15, 2011 | 05:00 PM
duste's Avatar
duste
77 and 79 will swap back and forth with no issued, 80 and up will not fit at all, 80-86 the ends are angled in quite a bit and would hit the lower and the 87 upare too norrow, they fit under the front fender. However, ford Vans all the way up into the mid 90's had a similar style bumper, the shape is identicle but I don't know about the frame width for the mount holes.
Old Feb 15, 2011 | 10:51 PM
Thunderbird7480
The salvage yard had a TON of vans with lots of good parts on them, I will check there.
Mine had a grill guard put on but I'll just say it was ill fitted. I dont know if it was this way when they installed it or if they hit something, but it was pushed back, breaking the grill inserts. The bumper is bent, and once I took the guard off it was worse than I thought. Basically going to rebuild the front over the next few months. Found fenders for $40 each. Inserts are salvagable if I fix them and paint them black. Need a new grill shell eventually if I want it to look finished. Bumpers are $30 at that yard.
Old Feb 15, 2011 | 10:56 PM
77&79F250's Avatar
77&79F250
Thanks duste, I forgot all about vans! Sounds like a plan there Tbird7480.
Old Feb 15, 2011 | 11:29 PM
John in AZ's Avatar
John in AZ
Vans from mid 70s-1991 is the same bumper but mounts way different. If I was going to do a van one I would make shure to get a couple of extra bolts to fill the vans stock mounting holes & then drill the correct holes in it & mount it just like your stock one.
John
Monsta
1983 - 2012 Ranger & B-Series
Apr 14, 2012 08:52 PM
SD26
Dec 19, 2009 10:51 PM
1966F100FE352
Mar 20, 2008 07:21 PM
KYFord
Jun 23, 2004 01:09 PM
FLOW_BOY
1978 - 1996 Big Bronco
Jun 2, 2003 04:33 PM
