Sponsored by: Real Truck
Help..2002 f250 no acceleration
Old Feb 15, 2011 | 09:36 AM
Dads65f100's Avatar
Dads65f100
Engine light came on, truck idles but does not accelerate. Any help is appreciated.
Old Feb 15, 2011 | 10:28 AM
tdpower's Avatar
tdpower
What engine do you have? I know on the diesels its common for the wire going to the gearshifter to rub and cause a short. This will take out the go pedal and cluster lights. If this is the case you need to remove the shroud around the steering wheel and find the short then replace the fuse. It's fuse # 45 on diesel trucks. I'm not sure if it's the same on gas engines.
Old Feb 15, 2011 | 10:29 AM
WestCoastTodd's Avatar
WestCoastTodd
Better pull those codes. Anyone you can borrow an OBD reader from? If not, they aren't too expensive, maybe $100 for a half-decent one.
Old Feb 15, 2011 | 01:53 PM
Dads65f100's Avatar
Dads65f100
Hi all, sorry for any confusion.
7.3 powerstroke, hooked up scanner no codes and then the truck started running like normal.
Old Feb 15, 2011 | 02:52 PM
tdpower's Avatar
tdpower
Might just be your idle validation switch acting up. It's on the pedal assembly.
Old Feb 15, 2011 | 02:56 PM
Franko72's Avatar
Franko72
Molon Labe
X2...I believe on 2002's you have to replace the whole pedal assembly.
bobs 80 f250
Sep 6, 2015 07:37 PM
American Air-1
May 4, 2015 09:24 AM
1986F150six
Feb 25, 2015 03:12 PM
86f250XLT-4x4
Dec 23, 2013 08:02 PM
67Grandy
17
Aug 5, 2013 08:18 AM
