Is this electric problem E4OD
Old Feb 14, 2011 | 09:27 PM
kevind95's Avatar
kevind95
I have a 94 f-350 7.3 4x4 with the E4OD Answer me this........I have a problem with it slipping out of drive . It drives and shifts just fine for about 2-4 miles (depending on how long it sits not running) then it will act like it it slips out of drive and the tach goes up. If i pull over and start out again it works fine even if i get on it but it will not go into second. First and Second gear and reverse work fine. I replaced the safety nuetral switch on the side of the trans and the plug fit loose on the new one and one of the plastic clips on the plug end is broken so I have two zip ties holding the connection tight .....QUESTION: .if this was loose and i hit a bump would that cause it to go out of drive and to slip?
<!-- / message -->
<!-- controls -->
Glouden
Mar 3, 2011 06:03 PM
RIDGEBOYZ
Dec 23, 2010 03:30 PM
maxtruck00
Dec 19, 2010 06:24 AM
tanker2008
Apr 13, 2010 11:25 PM
tanker2008
Illinois Chapter
Feb 7, 2010 01:14 PM
