Changing oil sender?
Old Feb 14, 2011 | 07:29 PM
2002exPSD's Avatar
2002exPSD
Do I have to drain the oil to change the oil pressure sender? 1996 f150 with 4.9
Old Feb 14, 2011 | 07:43 PM
6CylBill's Avatar
6CylBill
I don't remember if I had to drain my oil or not when I did this.
If I were you I'd play it safe. Drain the oil!
You should change that truck's oil anyway since you just bought it!
Old Feb 14, 2011 | 08:12 PM
2002exPSD's Avatar
2002exPSD
Problem is I just changed the oil
Old Feb 14, 2011 | 08:25 PM
6CylBill's Avatar
6CylBill
Is it possible to drain the oil and put it back into the engine?
Or is that a no no?
Old Feb 14, 2011 | 08:33 PM
2002exPSD's Avatar
2002exPSD
Definite no no. You'll contaminate the oil
Old Feb 14, 2011 | 08:39 PM
6CylBill's Avatar
6CylBill
Good point. Duh!
Well you could try it without draining the oil. Worst thing that could happen? You end up changing your oil anyway! Haha!
I wish I could remember if I had to drain mine. Some reason I don't think I did but I'm not 100% sure on that. Been a while and I have a hard time remembering dinner.
Old Feb 14, 2011 | 09:11 PM
Ford_Six's Avatar
Ford_Six
It's on the pressure side, so no need to drain the oil. It's also significantly above the oil level.
Old Feb 14, 2011 | 09:21 PM
2002exPSD's Avatar
2002exPSD
That's what I thought. But I've heard from others that I can't do it without draining the oil
Old Feb 14, 2011 | 09:52 PM
2002exPSD's Avatar
2002exPSD
Well I replaced the sending unit. That's not the problem. Still no oil pressure on gauge.
Old Feb 15, 2011 | 01:24 PM
2002exPSD's Avatar
2002exPSD
Well drove the truck dismornin to class. About halfway there I noticed that I had oil pressure. Guess it was the sending unit. Just had to sit overnight I guess.
