95 tranny issues
Old Feb 14, 2011 | 07:21 PM
gbdiesel's Avatar
gbdiesel
95 tranny issues
I have 95 f250 powerstroke recently noticed od light started flashing coming home from work last friday. Once I got home checked tranny fluid it was about a quart low but couldnt find any noticable leaks. When I checked the codes a tran fluid temp sensor circuit high input and a tranny overtemp codition. Topped off fluid and light quit and returned this evening and when checking fluid it was full.
Old Feb 14, 2011 | 07:55 PM
59JEEPSTANG's Avatar
59JEEPSTANG
Wish I could help explain this, best I can do is bump it to the top. Good luck.
Paul
Old Feb 14, 2011 | 08:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The code means that either the trans fluid temp sensor or the wiring to the sensor is bad. The sensor is mounted on the solenoid body inside the pan.
Walleye Hunter
Jun 14, 2014 09:02 AM
jaybob1807
Jul 1, 2013 11:55 PM
Pappyoutlaw44
Oct 5, 2010 07:02 PM
paetersen
Oct 7, 2007 05:09 PM
