Sponsored by: Real Truck
Left hand turn rumble
Old Feb 14, 2011 | 03:02 PM
strateman's Avatar
strateman
I know I've seen some ideas on the subject here before but couldn't locate it. When making a left hand turn I've noticed a rumble/shake noise. Drives normal straight and while turning right. Jacked up the truck and could not find anything rubbing or loose. Checked power steering fluid level, all's well. Truck is an '04 F-250 FX4, 6.0. Thanks in advance.
Old Feb 14, 2011 | 05:47 PM
White F250's Avatar
White F250
Wheel Bearings ?
just had mine replaced at 111,000
along with the destroyed rotors
Old Feb 14, 2011 | 08:56 PM
KJNDIVER's Avatar
KJNDIVER
My 01 has just started doing the same thing, or at i least i just recently noticed. Only does it when turning left, not right. And will not do it if going slow like in a parking lot and pulling into a parking spot, it wont do it. But get just a lil bit of speed (10mph?) and turn the street corner and it makes the noise, but only left hand turns.
I have bee chasing noises recently, addressed the "clunks" recently, changed sway bar bushings two weeks ago, and ball joints this past weekend. Clunks-B-Gone. I inspected all connections as you did and cannot find anything rubbing or loose. Changed bearings two years ago, but do have 50,000 on them now, but they looked good when i had em off this past weekend.
What do you guys think about maybe track bar joints/bushings being the culprit? Hell, ive just about changed the whole front end now, why not that too?
Old Feb 14, 2011 | 10:20 PM
cliles55's Avatar
cliles55
Is your tire rubbing in the fender well? Look for shiny spots.
Fordby4
32
Jan 3, 2011 12:43 AM
Deerslayinrenek
Sep 18, 2010 02:40 PM
midnitoil
1997 - 2003 F150
19
Jul 4, 2007 10:27 AM
cool_hand_luke
Nov 23, 2004 10:14 AM
Blubeast01
Jun 3, 2004 10:21 AM
