Rear vibration
Old Sep 26, 2013 | 07:25 AM
cory5517's Avatar
cory5517
Rear vibration
We'll after replacing u joint at rear off transfer case my vibration happens at any speed at half throttle. Since all u joints on rear driveshaft are replaced what are the chances my rear driveshaft is bent?
Old Sep 26, 2013 | 07:33 AM
Tugly's Avatar
Tugly
Mine was... and it was out of balance as well. The carrier bearing can cause this as well. I just took the whole shaft assembly to a driveline service and had them do their magic... but I spend more money on my truck than most others do.
Old Sep 26, 2013 | 07:40 AM
cory5517's Avatar
cory5517
I just had the shop replace my carrier bearing. Took my truck over to a reputable transmission shop here and was assured my problem isn't transmission related. However I haven't checked into my transfer case. I used 4wd while back and it worked flawless.
Old Sep 26, 2013 | 07:49 AM
Shake-N-Bake's Avatar
Shake-N-Bake
If you picked up a vibration after replacing u-joints then I would guess your problem lies with the joints themselves.
Old Sep 26, 2013 | 08:39 AM
TKegs763's Avatar
TKegs763
It's your carrier bearing. Mine did the same thing after new u joints. Installed a later model Neapco carrier bearing and she was as smooth as glass. If you have a lift, make sure it is spaced down 1/4" for every 1" of lift.
Old Sep 26, 2013 | 08:52 AM
cory5517's Avatar
cory5517
Shake-n-bake I had the vibration before I replaced u joints. Tkeg I just replaced the carrier bearing
Old Sep 26, 2013 | 10:52 AM
Shake-N-Bake
Oh, ok....you had the vibration before and after. I didn't get that from your original post. Sorry I jumped in without comprehending the situation more clearly.
Old Sep 26, 2013 | 10:56 AM
cory5517's Avatar
cory5517
No biggie my post was actually an update from a post from about two weeks ago
Old Sep 26, 2013 | 04:16 PM
TKegs763's Avatar
TKegs763
For some reason the carrier bearings are sensitive. I had a brand new factory carrier bearing replaced along with my new u joints. It was actually worse than before when I put it back in. I took it right back out and had them put a Neapco carrier bearing in and it was all better.
Old Sep 26, 2013 | 05:02 PM
TKegs763's Avatar
TKegs763
Old Sep 26, 2013 | 09:11 PM
cory5517's Avatar
cory5517
Ok where do I look for a neapco carrier bearing?
Old Sep 27, 2013 | 06:47 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Yes, what is this Neapco you speak of?
Old Sep 27, 2013 | 08:39 AM
mueckster's Avatar
mueckster
Look here for a distributor in you area. Aftermarket Products Distributor Locator | Neapco They refer to them as "center supports".
Old Sep 27, 2013 | 02:19 PM
camperJohn's Avatar
camperJohn
Rear Vibration
My 2000 F350, 77,777 miles, has a different sort of issue. When I brake from any speed the rear end vibrates horribly until I switch off the OD, then the beast stops as smooth as silk. Any one ever heard of this? Thanks, CamperJohn
I hope this doesn't qualify as a hijack...I just reregistered.....
Old Sep 27, 2013 | 02:21 PM
cory5517's Avatar
cory5517
I think I read something about this and it turned out to be the speed sensor on the rearend
