trans.Temperature gauge location
Old Feb 13, 2011 | 10:01 PM
odaat's Avatar
odaat
To start I have a 1997 F550-M\H powered with a460 did they use only E40D trans. behind the 460.If yes can some one tell me where is the best place you can install a temp. sender, need to keep a eye on its temperature high heat is a transmission killer as we tow and travel I-5 north to Canada some very steep hills.What are the best transmission filter oil filter , fuel spark plugs.
Thanks Jim
Old Feb 13, 2011 | 11:17 PM
ctubutis's Avatar
ctubutis
Jim,
The E40D wasn't offered in trucks until 1989.
With that being the case, I moved your thread here as these guys might be better able to
help you.
-chris
Old Feb 14, 2011 | 12:46 AM
Marine5811's Avatar
Marine5811
Hey Jim. I think there were some other transmission options behind 460s but can't say for sure. I run a 460/E4OD in my F250. The best place in my opinion to place a temp sender is in the pan itself. If you drop the pan and weld a threaded nut of the same thread pitch to it, you'll have yourself a bung to screw the sender into. As far as that other stuff, you're going to get lots of opinions here. Some of us (myself included) tend to stay with purely Motorcraft products (they're factory replacements.) Others like to upgrade to the more expensive product. One thing for sure, though, unless you have a high voltage ignition coil, don't waste your time with expensive spark plugs. Just get the cheapo Motorcraft ones and set the gap to .040. There are a lot of gimmick spark plugs out there that do THE EXACT SAME THING as the cheap ones, but they have three prongs and they're painted shiny green and they smell like cinnamon or whatever. Don't get 'em. Good luck man! Hope I helped a little. Welcome to FTE, by the way. Stick around for a while. Lots of good advice around here.
Old Feb 14, 2011 | 12:55 AM
86F150302's Avatar
86F150302
Here is where mine is in my E4OD. Just unscrew the little bolt thats there and screw in the sender.
Best trans filter : Motorcraft
Best oil filter : Motorcraft
Best plugs : Motorcraft copper
Old Feb 15, 2011 | 11:32 PM
odaat's Avatar
odaat
Thanks guys for the help good to talk people that know what have learned.
Jim
jim dillard
Mar 2, 2018 09:30 PM
hotrodfeguy
Oct 12, 2015 10:29 PM
BartKnox
Engine Swaps
Dec 17, 2014 07:35 PM
jim6346
Dec 10, 2014 05:28 PM
F-250Dude
Oct 6, 2004 10:55 AM
