identifying what rear diff
Old Feb 13, 2011 | 06:28 PM
fordboy300's Avatar
fordboy300
Question identifying what rear diff
i have a 86 f150 with the good ol' trusty inline 6 and i wanted to figure out how to identify if i have the ford 9" or the ford 8.8 is there a big difference in the two??
Old Feb 13, 2011 | 06:42 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Yep. 9" has a front drop-out unit, so the bolts are on the front side of the housing. 8.8" used a rear cover, with bolts on the backside of the housing.
Old Feb 13, 2011 | 06:49 PM
fordboy300's Avatar
fordboy300
oooh okay. i guess i have the 8.8 and not the 9 inch, bummer i heard the 9 inch a bad mother fudger to have!! LOL
Old Feb 13, 2011 | 06:53 PM
Rogue_Wulff
The 9" is well known for strength, but the 8.8" can be built to be just as strong.
I'm just not fond of the axle bearings used in the 8.8", the axleshaft itself is the inner race. Plus, the bolt that holds the center pin in the spider gears is very prone to breaking off. A real PITA when you need to pull an axleshaft.......
Old Feb 13, 2011 | 07:07 PM
fordboy300's Avatar
fordboy300
hey Rouge, another quick question is there a big difference between 80w90 and 75w90 gear lube??
Old Feb 13, 2011 | 07:16 PM
Rogue_Wulff
Not a lot of difference. The first number is the grade/viscosity at lower temps, and the second number is what it thickens to after reaching a certain temp.
The important part is the "GL-4/5" rating. I believe you need a GL-5 rated gear oil for either the 8.8 or 9 diff.
Old Feb 13, 2011 | 08:00 PM
fordboy300's Avatar
fordboy300
You think there would be a problem running 75w90 synthetic gear lube?
Old Feb 13, 2011 | 08:36 PM
Rogue_Wulff
I can't see where there would be. I run that in my RX7 trans and diff, and I do not drive it easy.
Old Feb 13, 2011 | 08:43 PM
fordboy300's Avatar
fordboy300
Same here with my truck! I just switch over to royal purple 10w30 man is it more smoother! I love it!! Nice the rx7 gotta love those rotorary motors!! I tried racing one of those for kicks man did he kick a** I got him off the line though!
Old Feb 14, 2011 | 08:39 AM
nolan62's Avatar
nolan62
I put Royal Purple 75W90 in my son's 8.8" with limited slip. It's quiet as a mouse.
Old Feb 14, 2011 | 10:08 AM
fordboy300's Avatar
fordboy300
thats what im going to put in my pickup..
z1121jack
Nov 16, 2009 04:56 PM
Danny D
May 25, 2007 09:21 AM
Innovative Detailing
Sep 1, 2006 10:25 AM
thomastedder
Dec 11, 2005 05:25 PM
Ratsmoker
Feb 5, 2002 01:53 PM
