6.0L Problem Prevention
Old Feb 13, 2011 | 07:57 PM
Jigger2020's Avatar
Jigger2020
Did anybody mention gauges, you need to watch what your motor is doing to prevent problems: fuel pressure, coolant temp, oil temp, exhaust temp....
Old Feb 13, 2011 | 08:01 PM
ZeroTucker's Avatar
ZeroTucker
Guages are already in...
Old Feb 13, 2011 | 08:13 PM
Jigger2020's Avatar
Jigger2020
Good man, well done.........always use Ford filters, change fluids regularly....use cetane booster....
Old Feb 13, 2011 | 08:17 PM
ZeroTucker's Avatar
ZeroTucker
5w40 synthetic with motorcraft filters every 5k, Ford fuel filters every 10k, Ford cetane booster every tank...
Old Feb 13, 2011 | 08:20 PM
Jigger2020's Avatar
Jigger2020
What do you need me for, nothing I guess
carry on then, prevention is the key
Old Feb 13, 2011 | 08:25 PM
ZeroTucker's Avatar
ZeroTucker
Haha, didn't mean anything by it.... Great advice!! Found that in the "advice for new 6.0 owners" thread about the time I bought the truck.
Old Feb 13, 2011 | 09:45 PM
Sullid01's Avatar
Sullid01
I wasn't trying to give you a hard time about the EGR cooler delete - just trying to save you some money. Remember, if your state changes inspection rules in the future, it could cause you a major PITA trying to put it back on (I am assuming you don't have inspections).
Guys have recommended using the blue hose from Ford rather than the hose that comes with most of the delete kits and getting new bolts for the up-pipe and y-pipe exhaust connections from Ford (rather than the bolts that come with the kits). I think you'll need 4 y-pipe bolts w300013, 6 y-pipe nuts w300051 and 2 y-pipe to y-pipe adapter bolts (don't know the part number).
Good luck!!
Old Feb 13, 2011 | 10:16 PM
ZeroTucker's Avatar
ZeroTucker
Sullid, didn't mean to come across hostile if I did.
Any particular reason for the Ford bolts? I could see if the EGR delete kit comes with junk hardware I guess. Would it be cheaper to just get Grade 8 bolts from the hardware store?
Old Feb 13, 2011 | 10:29 PM
Sullid01's Avatar
Sullid01
I am not sure, but the recommendation came from the FORD techs on here (cheezit or m-chan, I believe). I think those bolts are prone to freezing up and exhaust leaks are probably the most common problem after messing with those bolts. I think they are very inexpensive. partguyed.com is a great place to get these things much cheaper than at your local Ford- they will all be OEM from Ed (he is a Ford dealer, but extends us a better price than most of the dealer will give).
Old Feb 13, 2011 | 10:34 PM
ZeroTucker's Avatar
ZeroTucker
Thanks, I'll look into it. I would love input from cheezit or m-chan on this thread.
Old Feb 13, 2011 | 10:43 PM
Sullid01's Avatar
Sullid01
I tried to find the the link to the thread that mentioned all of this, but there are soooooo many EGR delete threads, I couldn't find it. It is out there though. I think the title had something about the best kit for EGR delete.
Old Feb 14, 2011 | 01:35 AM
broncoformudv's Avatar
broncoformudv
The 2005 model year are the ones that use the Stand Pipes and dummy plugs not 2003-2004 model years.
You can get a new IPR screen for a few bucks as well or just clean the old one.
The Y-pipe to up pipe bolts can be a biatch or they can come right off. I don't think they need to be replaced with the factory ones but thats just my opinion. One of mine broke while doing my head gaskets so I replaced it with a standard hardware store one.
Cobbs Diesel had the best price on the intake gasket set and it came with every gasket, seal, and o-ring you could possible need and then some.
Being in as far as you are I would do the head gaskets and studs buts thats just me. If you do not feel comfortable going into your engine that far then don't mess with it.
While having everything apart keep it clean, put rags or towels over anything that you have apart.
Do a very thorough pressure wash of the top half of your engine prior to pulling everything apart it will make life a lot easier and cut down on the risk of contaminating any openings to your engine while working on it.
Old Feb 14, 2011 | 01:47 PM
  #28
ZeroTucker's Avatar
ZeroTucker
There is a post here on FTE where a guy has a blown motor due to a melted stand pipe with a 2004 6.0L.... I'm not familiar with the changes in model year, please explain your statement of the stand pipe and dummy plug only in 2005-2006.
oughtsixbigred
May 22, 2015 03:25 PM
kbf1961
Apr 12, 2015 08:31 AM
diesel_dan
May 4, 2014 07:19 PM
colo_dually
Jun 18, 2011 10:10 PM
tharepairguy
Feb 28, 2011 09:50 PM
