6.0L Problem Prevention
Old Feb 13, 2011 | 04:50 PM
ZeroTucker's Avatar
ZeroTucker
I've had my 2004 6.0L for almost a year now, 53k on the truck and no problems as of yet.... I plan on running some mild tunes but do not tow heavy and by no means do I abuse my vehicle. I wish I had the time/money to tear down the whole top end and replace head bolts/gaskets and truly have a "bulletproof" 6.0L but 3k in parts is a little much for me.
After a lot of research here is my $750 plan, let me know what you guys think.
Upgraded turbo oil drain line - $40
Turbo gasket/bolt kit - $17
Oil cooler rebuild kit - $250
Intake manifold gasket set (most o-rings/gaskets on top-end) - $70
EGR delete kit - $150
HPOP pressure fitting upgrade kit - $58
Blue spring kit - $25
CCV Reroute - Already have the parts
Coolant and VC-9 flush - $100
I figure this will allow me to avoid the problems guys have with the EGR cooler and oil cooler (come on Ford engineers, wtf) and as long as I monitor my Pyrometer very closely I can skip out on head gasket problems, hopefully....
Am I correct in my reasoning or am I way off base? Should I just save the extra money and do the whole top-end, studs and all??
Old Feb 13, 2011 | 05:56 PM
mblanken881's Avatar
mblanken881
subscribing
Old Feb 13, 2011 | 06:04 PM
lenzhotrod's Avatar
lenzhotrod
I highly endorse a coolant filter kit and ELC coolant. Why are you doing the oil cooler change? Have you tested to be bad? I have the upgraded turbo drain and question if it really does any thing.
Old Feb 13, 2011 | 06:10 PM
ZeroTucker's Avatar
ZeroTucker
According to what I've read here on FTE, the early oil coolers had small fins, clogged easy, and the cloth screen can tear and clog it. If I have the thing tore down that far, it makes sense to me to upgrade the fins in the oil cooler and switch to a stainless screen. Oil not cooling properly can contribute to head gasket problems, HPOP problems, and injector problems.
Turbo drain to me is just another smart $30 while I'm in the truck. EGT's can run very high in these trucks and I would rather spend $30 than buy a new turbo after I trashed it with coked oil.
Again, this is my first diesel truck and I may be incorrect, this is all information I have gathered from FTE and other forums.....
Old Feb 13, 2011 | 06:40 PM
2006powerstroke90's Avatar
2006powerstroke90
If you truly want to make it bulletproof I would do most of what you listed and the head studs and gaskets.
Just my 0.02
If I had more money I would have done some of what you listed but as I type this I have my headgaskets and studs getting done in my truck(doing the work myself)
Old Feb 13, 2011 | 06:46 PM
ZeroTucker's Avatar
ZeroTucker
2006powerstroke90 -
I would love to do the head studs AND everything I listed and believe that I can turn a wrench well enough to. The problem is I would be looking at $1,800-$2,000 in parts plus machining costs for the heads.
I'm looking for a more cost efficient way to prevent head gasket failure and be able to drive this truck for the next 15 years....
Old Feb 13, 2011 | 06:52 PM
2006powerstroke90
I totally understand where your coming from believe me, but I'm only about 800$ in parts for the head gaskets studs intake gaskets injector o rings valve cover gaskets and an intercooler boot.
I still have to buy filters oil and coolant.
But if you are comfortable with working on your truck I'd say go for it. Just monitor temps and fluid levels and you should be good, especially since you have lower miles. I just passed 201,000 lol
Old Feb 13, 2011 | 06:56 PM
ZeroTucker's Avatar
ZeroTucker
Are you doing the studs because of a failure? Or just getting nervous after 200k? $800 isn't too bad I guess. Would I be safe to assume my plan of action could get me to the 200k mark?
Old Feb 13, 2011 | 07:02 PM
2006powerstroke90
Yes I am doing them to failure. I had a lot of coolant puke.
I could see it on the front drive shaft and the frame rail behind the left front tire. It was pretty bad. I have the heads going to the machine shop tomorrow for a cleaning checking for cracks and re surfacing them.
As for you hitting the 200k mark I wouldn't see why not...just take care of it and it will take care of you
Oh and if you do choose to do that work we love to see pictures
Old Feb 13, 2011 | 07:05 PM
ZeroTucker's Avatar
ZeroTucker
Pictures will be included, definitely! How does the inside of your intake manifold look at 200k? Are you going to have it cleaned?
Old Feb 13, 2011 | 07:13 PM
2006powerstroke90
It's not bad. I thought about having it cleaned when I took it out the first time to do the egr delete but I never did. I have read if its not thatbad to not worry about it.
But if there's any questions or problems you have while doing it I'm ready to help, and I'm sure many others will also.
Old Feb 13, 2011 | 07:16 PM
Sullid01's Avatar
Sullid01
It sounds like you are doing this yourself. ARP studs will run about $450 and stock gaskets are about $200. If you have the talent to do this yourself, the extra $650 is going to be well worth it.
I agree with adding a coolant filter. I plan to switch to ELC the next chance I get.
There is a turbo drain tube ($25) and a supply tube ($80), both of which are upgraded. They help lube and cool the turbo and prevent coking of the oil in the turbo.
Since you are 2004, I'm not sure you have to do the STC HPOP fitting - I don't think so (thought it was just 05-06 - hopefully someone else will chime in). You could do the dummy plugs and stand pipes (about $100)- they have an upgraded o-ring and help prevent no start from high pressure oil leak.
I would leave the EGR cooler alone and save that money - the coolant filter and oil cooler swap out should protect it. Are you having problems with the oil cooler EOT-ECT>15?
Finally, if there is nothing wrong right now, why not wait - this is a pretty massive project even if you are an awesome mechanic.
Old Feb 13, 2011 | 07:26 PM
ZeroTucker's Avatar
ZeroTucker
I appreciate that, probably can use all the help I can get!
I am planning on doing this but trying to not do studs/head gaskets. I am by no means an awesome mechanic.... but just pulling the turbo and intake manifold doesn't seem bad.
Good info on the STC fitting, after a quick search you are correct. Glad I can cross that $50 off my list....
I will look into adding a coolant filter to my list. As far as an EGR delete, the cooler is obviously a very weak point in the motor and I want to rip it out of there. Personal preference I guess. No problems with the oil cooler but again, I'm trying to avoid ever having to pull the heads on this thing...
Old Feb 13, 2011 | 07:30 PM
moebdick's Avatar
moebdick
x2 on the coolant filter. You might also consider using a silicon-free ELC coolant, and pull the IPR valve to clean the inlet screen.
Old Feb 13, 2011 | 07:47 PM
ZeroTucker's Avatar
ZeroTucker
Adding:
Coolant filter kit - $130
Stand pipe/Dummy plug - $112
Up to $900..... Will it ever end??
