Oil in intercooler????
Old Feb 13, 2011 | 08:38 AM
bleeds blue's Avatar
bleeds blue
While changing the valve cover gasket on the passenger side the other day I had to remove the intercooler tubing. I noticed there was a fair amount of oil inside. Somebody mentioned maybe I need to rebuild the turbo? Any ideas?
Old Feb 13, 2011 | 08:47 AM
RRranch's Avatar
RRranch
It's probably just from the crankcase vent on the left valve cover.
Old Feb 13, 2011 | 09:19 AM
Muktown's Avatar
Muktown
Yup that's normal. The crankcase vents into the intake so you will get some oil in the intercooler
Old Feb 13, 2011 | 10:38 AM
bleeds blue
Ok good! Can I put a filter on the valve cover and plug the hole in the intake?
Old Feb 13, 2011 | 10:49 AM
Robbgt's Avatar
Robbgt
I don't know if you can do a filter right on the CCV doghouse, most just flip the doghouse around and put a piece of tube up over the brake booster and vent to athmopsphere under the truck
here is a link to it on an SD w/ a filter trap
Welcome to guzzle's CCV mod web page
Crazyotto1
Nov 13, 2014 04:55 AM
cutlass
16
Aug 26, 2014 07:48 AM
shadows4
Feb 11, 2014 01:16 PM
Mr. Sandman
Feb 10, 2011 06:27 PM
mtgrzlyman
16
May 13, 2006 10:03 AM
