Transfer Case Sludge
Old Feb 12, 2011 | 09:55 PM
HarborHarborHighBoy's Avatar
HarborHarborHighBoy
I recently decided that the noise from the transfer case (divorced NP205) needed to be addressed. I'm in the process of fixing the truck after it has sat for 10 years. I opened the drain plug and a thick sludge tried to make its way out. I ended up taking off the rear covers of the transfer case. It is currently cold outside so the sludge is slowly making its way out. Is there a good way to flush this stuff out. I have read that running ATF through as a flush might work. Any other suggestions? Also, what should I fill it with when I'm ready?
Thanks!
Old Feb 13, 2011 | 12:34 AM
tikkakoski's Avatar
tikkakoski
Ive always just drove the truck for a bit before i drained it to get it goood and warm. It flows better that way. And these old trucks call for a pretty thick gear oil in the transfer. I know most people on here use 80-90w gear oil or 85w140 gear oil. I use 85w140 gear oil and it works great. I also use it in my diffs. Happy draining!
Old Feb 13, 2011 | 12:52 AM
sleepy_fella's Avatar
sleepy_fella
Id have to agree with the warming it up. Cruise up the freeway an exit or two then back. Worked well for me. I know my tranny(4 speed) and my transfer had atf runnin in it from the po. I don't think he was just flushin it either >_>
dune9175
Jun 29, 2016 03:50 PM
Erik Jaeke
Sep 21, 2015 10:44 AM
wufnu
Jul 27, 2015 08:47 AM
dave03835
Dec 19, 2014 01:15 PM
JPMallory
Jun 17, 2014 02:21 PM
