fuel pump
Old Feb 12, 2011 | 04:53 PM
joeyd61's Avatar
joeyd61
fuel pump
A friend has a 03 F350 6.0 and is stranded... where is the fuel pump located????is it the same as my 03 7.3???
Old Feb 12, 2011 | 04:58 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
On the frame rail under the driver side door.
Old Feb 12, 2011 | 05:01 PM
amdriven2liv
Quick link:
Page 29: Fuel Supply System
Old Feb 12, 2011 | 05:03 PM
amdriven2liv
Fuel flow. Heck, might as well have it all!
Page 28: Fuel Supply System
Good luck!
Old Feb 12, 2011 | 05:06 PM
amdriven2liv
Trouble shooting no start:
https://www.ford-trucks.com/forums/8...ml#post7807959
Old Feb 12, 2011 | 05:08 PM
amdriven2liv
And the 03's have had issues with the ICP. Which on His is located under the turbo.
Old Feb 12, 2011 | 05:17 PM
william_04_x's Avatar
william_04_x
Reps for 5 excellent posts in 10 minutes, amdriven.
Old Feb 12, 2011 | 05:22 PM
amdriven2liv
Thanks William
It's easy with all that priceless info in the tech folder. And the years of knowledge shared by so many on this forum.
Hope they get his truck back up and running.
joeyd61's Avatar
joeyd61
Thanks for all the replys.....what his truck is doing----wont run over 40mph,about 20 minutes it will shut down, wait appx 15 minutes and it will start back, changed fuel filters yesterday (problem was befor the change)..draining the fuel lines (for water)...drain open, turn the key on to pump a little fuel out and don't get much...pump is humming for a short amount of time then gets quiet.....Thinking eather tank is stopped up or fuel pump is out......
Old Feb 12, 2011 | 05:25 PM
amdriven2liv
Well, you can take the cover off the top fuel filter to figure that one out. Just don't use the 1/2 inch socket hole in the cap if you can. 24mm socket works best.
Take cap off and see if the fuel is getting to it. Key on will start pump.
Old Feb 13, 2011 | 04:23 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by joeyd61
...pump is humming for a short amount of time then gets quiet......
It's normal for the pump to run for about 30 seconds then shutoff if the motor doesn't start. All you have to do is recycle the key. Are you sure that the fuel tank is full? These trucks are notorious for having bad fuel gauge senders.
Old Feb 13, 2011 | 08:09 AM
joeyd61's Avatar
joeyd61
Plenty of fuel.....will the pump shut off with the drain plug removed?
Old Feb 13, 2011 | 09:50 AM
npccpartsman
Yes. It's only if gets a motor run signal that it will stay running as there is no fuel pressure sensor to control it.
