LED Cab lights
Old Feb 11, 2011 | 10:06 PM
glovemeister's Avatar
glovemeister
LED Cab lights
I noticed the ad on these forums talking about a strobable cab light. However, they wanted like $225 per five or maybe even one I think not including the harness.
So my question is if I go with a set from Pacer (smoke or clear I like best) with the harness I assume it would just be plug and play with the cab light option wired into my truck as all came that way.
Second is there a best kind to get smoke clear vs amber?
Lastly, I would assume that I could wire my lights with a strobable function with a flasher right? How would I go about actuating this flasher to transition from solid on to strobing?
Old Feb 12, 2011 | 08:48 AM
Franklin2's Avatar
Franklin2
I don't know what you are trying to accomplish with strobing cab lights, but a true strobe lighting system takes special lights and a special high voltage box to drive them. You can make regular lights and led lights "blink" like turnsignals or christmas lights, but they won't be a true strobe light with the high power flash.
I doubt you will find a aftermarket harness that will just plug in to the Ford plug. I have heard there is a plug on the driver's side kickpanel area, but I could not find it on my truck, but the darkbrown wire is there, and you can just tie into that for the cab roof marker lights.
Old Feb 12, 2011 | 11:31 AM
glovemeister
It just looks cool and from seeing the strobing leds by Atomic who had an add here it made me think. However, from what I could tell it was about $50 for the harness and then it appeared $255 for a professional series strobing light (it didn't appear to be the package either). I anticipated if they could do it then so could I but I see what you are saying.
Old Feb 12, 2011 | 02:52 PM
Diesel_Brad's Avatar
Diesel_Brad
No aftermarket cab lights will be a plug and play with your stock Ford ones. You will have to cut and splice.
As far as "strobing" cab lights, that is just lame and illegal
ru67
May 28, 2016 12:21 PM
555 Studio
Electrical Systems/Wiring
Feb 8, 2016 07:02 PM
motorboatink1ng
May 20, 2015 09:27 PM
mosigndude
Dec 22, 2014 09:06 AM
Ford150/428/dud
Jun 15, 2007 03:16 PM
