High pressure oil pump
2003 6L Diesel Stall and no warm start; Injectors replaced recently
All injectors replaced less than 1000 miles. Running great. Then... pulling slight hill with light load. Loss of power (like turbo gone!) then stalled when coming to a stop. No start - but does turn over.
Mechanic looking at HPO system, as seems with all other posts with similar description. My question: Coincidental timing just shortly after injectors replaced?? Injector inlet O ring issue very possible since injectors recently done?? Issue with injector replacement and oil rail?? The issue "smells bad" as the timing of injector replacement is so close.
Tom
Tom
hey there, I had the same type of problem and when we changed the oil filter and made sure there was the full 15-16 qts of oil in it the problem stopped. Yes, mine left me stranded a few times because of this issue too!! Once even in the drive through, that was fun for almost 2 hours. Luckily I didn't drive it that far so it wasn't that hot so didn't take that long to cool off.
Was not so lucky. Ended up being the oil cooler and ICP. $2500 expense due to Fords poor design. That on top of 2600 for injectors last month. Very disappointed for only 170 miles. This @#$&% truck has cost me 10k more in repairs than my 96 7.3 L diesel. It just turned 280k and no engine work!
(and I assume you meant you have 170K miles on the truck?)
greasolution
18
02-29-2016 08:53 PM
FPChickey
01-07-2011 07:00 PM
