Door tag Axle code
Old Feb 10, 2011 | 07:53 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Door tag Axle code
Hi all,
I find two different ratios on two different door tag axle code charts, any one know whats correct ???
Code: 45
I get 3.55 on one chart 4.10 on the other, I believe it's 4.10 just want to be sure.
It is a 1994 if that matters.
Thanks
-Enjoy
fh : )_~
Old Feb 10, 2011 | 08:00 PM
IHdieselfan's Avatar
IHdieselfan
4.10 non limited slip
Old Feb 10, 2011 | 08:34 PM
Festus Hagen
Methanoholic
Thank you.
-Enjoy
fh : )_~
Old Feb 11, 2011 | 12:07 AM
Dark Horse's Avatar
Dark Horse
I don't know if this helps mine is marked C5 and all the available info says its a 4:10 rear end I will look tomorrow and see if there is a tag that says what it actually is.
Mine is a 93 F350 crew cab.
Mark
Old Feb 11, 2011 | 08:44 AM
Festus Hagen
Methanoholic
As I understand it, C5 would be a Limited Slip 4:10.
This is what I read someplace ... I forget where.
If the first digit is Alpha it's Limited Slip.
If the first digit is Numeric it's NON Limited Slip.
The second digit is a code and needs a chart ... The chart I found said 5 = 4:10.
I do not know if that is accurate info, another chart showed code 45 to be NON limited slip 3:55, thus my original query.
-Enjoy
fh : )_~
Old Feb 11, 2011 | 09:12 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
this one appears to be accurate
What is my Ford rear end ratio, do I have positraction - Drivetrain.com
Old Feb 11, 2011 | 12:37 PM
Lazy K's Avatar
Lazy K
Ford Axle Code Chart .: Articles Good one here also, ignore where it says 1991.
Old Feb 11, 2011 | 04:41 PM
snaponprofile's Avatar
snaponprofile
Mine says C5, that means I have LS's?
Old Feb 11, 2011 | 05:12 PM
Festus Hagen
Methanoholic
Yup, I'd say so, Lucky dog!
-Enjoy
fh : )_~
Old Feb 11, 2011 | 05:16 PM
snaponprofile
Thats a good thing right?
Old Feb 11, 2011 | 05:22 PM
FORDF250HDXLT
like everything,there's always a compromise snapon.
when it comes to limited slip diff's there is a fuel economy decrease,however how significant it is over a open diff,i just don't know.likely not a whole lot,however it probably depends on ones average terrain i guess.however,for the added traction they provide,i highly doubt the tiny increase in fuel consumption amounts to anything.a hardcore hypermiller may avoid them on purpose,but the average joe isn't going to worry about it.im an in between hypermiller and average joe,and id never on purpose think about ditching a LS diff if i had one,for an open.however i wont trade one in for one either lol.
the basics:
Limited Slip Differential
47CP
May 8, 2017 10:06 PM
rogerranger2122
1983 - 2012 Ranger & B-Series
Oct 9, 2016 04:49 PM
f100today
Jul 19, 2016 09:22 PM
Selfhl1
19
Oct 23, 2015 08:44 AM
ComputerCowboy
Jan 5, 2012 12:20 AM
