2003 E350 15 Pass Rear Axle Codes
The rear end in our 2003 E350 recently grenaded and we have decided to fix it as cheaply as possible and sell as the van is in somewhat rough visual shape.
I am trying to source a complete assembly from a salvage yard and am having trouble figuring out the correct part. The axle tag is missing and the code on the door jamb is "34"
I know it has a Dana axle, presumably the Dana 60 (9.75 ring gear)and is a semi floating. Obviously disc brake and SRW. It currently has a 4.10 ratio, but I want to put a 3.55 or 3.73 back in it (I have a friend who works at Ford and can reset the computer like he did when we put in the 4.10)
So, my question is: What is the difference between all these axle codes?
https://macksautoparts.hollanderstor...assembly,-rear
Any ideas how to decipher what axle I have, or need, or how to find the Axle tag code they reference?
Thanks,
DaveW
Then, you can find all the part #'s for the ring and gear, bearings, etc:
Dana Holding Corporation - The Expert Axle Bill of Material
Or, if you're near Flagstaff, AZ you can have my semi-floater out of my 2004 E350 for $150. It's a runner in good working condition. I did a swap to a full-floater for the extra load capacity on my 10,000lb van. https://flagstaff.craigslist.org/pts/6123634153.html
