HELP WITH THIS SWAP
Old Feb 10, 2011 | 10:13 AM
SACGNS's Avatar
SACGNS
HELP WITH THIS SWAP
Ok, so i have read all the 300 to 351 swap pages i can find an im still confused as hell because they all jump around so much. my question is i have a 1989 f150 with a straight 6 with a 5 speed manual.
i understand the trany will bolt up to a 351 but beyond that im lost,
will i need to find mounts and perches for a 351 or will my existing mounts work? and as far as wiring harnesses go will i need a new harness seeing as im going from efi to carbed?
p.s. i will be using a performance unlimited 351w Ford Turn-Key Crate Engine With 425 HP
Old Feb 10, 2011 | 11:10 AM
Conanski's Avatar
Conanski
You need V8 frame perches and engine mounts and the I6 versions must come off or they'll be in the way.
You also need a 28oz flywheel for your transmission, the I6 has 0 imbalance so that flywheel can't be used.
And the wiring harness really doesn't matter since you won't need most of it, I'd suggest removing the engine portion and either making or buying a carb harness for the couple things that will need it like the gauge sensors.
Old Feb 10, 2011 | 12:15 PM
Muliefever's Avatar
Muliefever
or just put some money into that 300, and destroy the 351's! just sayin
Old Feb 10, 2011 | 02:16 PM
SACGNS's Avatar
SACGNS
Ya it can be done with a 300 but not the level of modifications i want to get in to. also how much tq can the stock 5speed handle?
Old Feb 10, 2011 | 02:26 PM
Duct Tape Racing's Avatar
Duct Tape Racing
Get the zf 5 speed. The Mazda 5 speed will not handle that motor if it's worked hard.
Old Feb 10, 2011 | 02:29 PM
SACGNS's Avatar
SACGNS
Even with a bone stock 351?
Old Feb 10, 2011 | 08:11 PM
Duct Tape Racing
Itl be fine with a stock 351..but as far as pulling, wheeling, or things like that go, it wont last long. ZF is the same transmission just made for all that stuff and ALOT stronger. IMO, A hell of alot more practical.
Old Feb 10, 2011 | 08:35 PM
fordman1090's Avatar
fordman1090
I would not run a mazda 5-speed behind a 351. Even if its a stock 351. It wont hold up long at all. Its got the wrong ratios and is far to weak. Its only rated to about 320ft/lbs of torque IIRC.
You need a zf5 tranny.
Old Feb 11, 2011 | 06:54 AM
SACGNS's Avatar
SACGNS
Well that sucks looks like im looking for a trans to, So my next question is use a zf5 or zf6 also will i need new crossmembers and wiring harneses for that
SuperDutyScaler
Jan 6, 2014 10:56 PM
Granny Gear
16
Jun 24, 2012 07:25 PM
E30tdf
17
Mar 16, 2010 11:28 PM
torquemeister
17
Mar 5, 2010 09:59 AM
Blueoval_boy_64
Engine Swaps
Dec 16, 2007 11:39 AM
