I have a 1999 5.4 2v, can i put a 4v in it? 2v upgrades?
Im at a cross roads on my 1999 f250, i am having top end problems so im trying to explore my opions to upgrade the heads or do a complet 4v swap? I'm really interested at doing a 4v swap but im having a hard time finding information on anyone doing it in the trucks. HELP PLEASE!!!
You'll need a '99-'03 4V 5.4L.
JL
I didn't have time to look it up on the F150 forum but I had considered a 4.6 4v swap in my '99 F150. The advice I recall regarded the difference in Romeo and Windsor engines; you should check the VIN to get the same manufacturer to avoid changing the flex plate. The other issue was the PCM; consider getting the 4v PCM or a tuner (check with the tuner manufacturer to make sure things will work) and don't beat on it too much until you address the 2v PCM issue.
Best of luck,
Best of luck,
Overlook the snippy comments in #2 this F150 forum thread clicky here but you'll get a better idea of what may be involved.
AtomicBubbles
05-05-2015 06:47 AM
