OT.... stereo question.
Old Feb 9, 2011 | 07:50 PM
bcaughhorn's Avatar
bcaughhorn
ive had a pioneer avic n2 (cpn 1955) in the ol girl. but it has a short now and doesnt flip open and closed. just stays open. i just run up on a deal on cl for a pioneer avic f900bt. double din. the factory plug was hacked when i got the truck and i dont want to cut the wires unless i have to..
my question is does anybody know if the plug with the power wires are the same on the radios???
i know i could pull it out and compare them but im being lazy and i want to have everything ready so when i pull it out it doesnt go back in for me to run to the store to get the connectors
Old Feb 9, 2011 | 09:46 PM
BillyBob69's Avatar
BillyBob69
The powerplugs from similar stereos, even different brands are very very close to being the same. Since they are both Pioneers, I would say yes. I know the plug for my cheapy Dual is almost identical to the plug for my old Kenwood. Just a little tab on the kenwood harness that wouldn't let it plug in. I just snipped the little tab and it worked fine.
Old Feb 10, 2011 | 04:43 AM
bcaughhorn's Avatar
bcaughhorn
I got off my lazy ase and went and pulled mine out. They are different
Old Feb 10, 2011 | 05:13 AM
SLUF681's Avatar
SLUF681
The experience I've had with stereos is somewhat limited but for the most part red and yellow are usually your power wires. One is hot all the time, the other is "key on" hot. Don't remember which is which. Both are usually fused at the head unit itself though. As far as the outputs go, all bets are off. Google?
Old Feb 10, 2011 | 05:23 AM
bcaughhorn's Avatar
bcaughhorn
i know what the colors are for. i was just trying to see if i could use the plug from my old radio thats already wired to my truck for my new radio
Old Feb 10, 2011 | 05:29 AM
SLUF681's Avatar
SLUF681
Gotcha. I misunderstood what you were looking for. Good luck anyway!
Old Feb 10, 2011 | 08:56 AM
BillyBob69's Avatar
BillyBob69
Yea sometimes ya just gotta do it. Try calling Car Toys or Best Buy and see if they have the harness adapters. Sometimes you can get harnesses to keep you from having to chop wires making it plug -n- play.
Old Feb 10, 2011 | 09:00 AM
bcaughhorn's Avatar
bcaughhorn
Only problem with that is the po hacked the factory plug out for the radio. So nothing to plug in to
Old Feb 10, 2011 | 09:06 AM
rat49f6's Avatar
rat49f6
you could always get this and fix what the previous owner messed up
Old Feb 10, 2011 | 09:51 AM
cgl's Avatar
cgl
You can get what's called a "reverse harness". It's basically a replacement for the factory plug. Simply splice the wires to the factory wires and you'll have an almost new OEM connector. Then you can get a normal Ford Adapter to splice into your head unit. Connect the two together and voila.
98+ FORD POWER/SPEAKER
Old Feb 10, 2011 | 09:59 AM
rat49f6's Avatar
rat49f6
thats the link i was trying to post but apparently didnt work
madsonp
May 20, 2017 05:51 PM
Billy Hell
Dec 14, 2007 02:53 PM
guiri
37
Oct 9, 2007 03:36 PM
PowerstrokeJunkie
Sep 19, 2007 06:17 PM
jekuo
16
Feb 21, 2007 11:17 PM
