Posts that make you say "What the Hell?"
#796
"Anybody had any luck installing an electric exhaust cut out on a 4.6L explorer? (I have a 2003 4x4 EB) I was toying with the idea of puting one after the cat but befor the muffler to "bark back" at the stupid imports with coffee can tips at the lights, and it just might add a bit of power too....."
No, but I did have luck restraining myself and deleting my comment suggesting that a cutout identifies the driver as the south end of a northbound horse.....
#798
Received 5,160 Likes
on
#800
on
#802
on
#803
#804
#805
Just had front end work done. New hubs, seals, CV joints, ball joints, etc. Original problem was hitting the smallest hole on the road or even running over a reflector would cause such as shaking and grinding vibration in the truck you had to stop and try to move again. Problem is now fixed and drives preety smooth.
New problem...When approaching 55+ MPH there is what feels like air pressure that builds in the inside of the cab and you can feel that pressure change in my head/ears and stays consistent even with the truck in neutral and coasting downhill at 55+MPH. Cracking the drivers side window barely makes any difference.
My bug shield is also cracked into two pieces. Going to remove that tomorrow so what should I check while doing this work?
#807
on
#808
Here's one offa ebay
Lot of 2 Ford Rebuilt Vintage Mechanical Oil Pumps See Pics 351 302 | eBay
#809
#810
Beetle brain failed English 101. another members thread, then typed this gibberish in '73/79 forum:
More gibberish in second post:
the light switches new cant get running lights and headlights the same time pulled out all the way to get head lights to push in ways to get
97 with th with the headlamp switch is
