question on eadge evolition 15000
I have 96 powerstroke with 315000 mi on it has anyone used this program on a truck with anywhere this many miles it's been well maintained over the years & pm,s pulled reagurly I pull 30 ft toyhauler at 10.000 lbs used eadge ez for a while thought it was giveing me trouble sold it and found latter the trouble to be the uvc harness 96 F250 sc 4x4 k&n air intake w 3 in down pipe and factory exhaust im new here and would be thankful for any info
The Evolution is fine. It may shift a little firm (if you have an automatic), but there won't be any additional power gains from any one of anybody's beloved "custom tuners".
I'm leery on the use of the Edge Evolution. We have seen quite a few guys that end up with PCM issues from using the Edge Evo and usually have to go to the dealer to get it reflashed or install a new PCM to fix the issue. Just know that there have been PCM issues spurred from the Evo.. Not a crazy amount of them, but some.
Cody, I realize that PHP has been around many Evo programmers, just stating the experiences I've seen on this forum.
Also, before you start towing with a chip on your truck, I would recommend getting a set of guages to monitor temps. Most of us run a boost guage, EGT guage(exhaust gas temp), and for auto transmissions, a trans temp guage. The boost guage is not really neccessary, but the EGT and trans temp is. If you have a manual trans, all you need is the EGT guage.
daybreaker
02-18-2009 06:13 AM
cappy
01-07-2004 02:46 PM
hawkint
09-07-2000 01:28 AM
