STOP THE DOOR RATTLE
Old Feb 11, 2011 | 03:06 PM
  #31
Sw1tchfoot's Avatar
Sw1tchfoot
I need to redo the hinges and striker on my truck, adjusting the striker bolt did help but the doors still don't close as easily as my dads 1986 F350. All four doors on it close with perfection.. With the doors opened on it I can give them a push with a finger and they close correctly.
Old Feb 11, 2011 | 04:44 PM
  #32
Shark Racer's Avatar
Shark Racer
Just out of curiousity, where do these go on the tailgate?
The vertical part of the "|_|" shaped striker on the inside of each fender?
I think adding these will make my life significantly better.
(anyone have installed pics?)
Old Feb 11, 2011 | 05:10 PM
  #33
GLR's Avatar
GLR
Don't go on the tailgate.
Old Feb 12, 2011 | 12:26 PM
  #34
Galendor's Avatar
Galendor
Replaced the door strikers on my F150 today - piece of cake job. Now the doors close easily, no slamming required! Thanks for the help.
Old Feb 15, 2011 | 01:20 PM
  #35
Rogue_Wulff's Avatar
Rogue_Wulff
Well, apparently sometime during the recent cold spell, the plastic sleeve on my passenger door striker busted. I started hearing a rattle from the door.
The replacement bushings are a great idea, but the washer doesn't come off the end of the bolt. I guess I'll just bite the bullet and buy a couple new striker bolts to put in the truck. I may actually still have one in my toolbox, just have to dig thru it. I swiped a couple many years ago from a car that had been crashed, and only used 1 many years ago.....
For a temporary solution, I got out a roll of black electrical tape, and made 15-20 laps around the bolt. Cheap, but effective.......
Old Feb 15, 2011 | 03:25 PM
  #36
Shark Racer
The PEX solution that Franklin recommended works great on my truck. I have about 4.5 feet left of the stuff if you'd like me to cut some off and mail it to you. You can just split it and feed it over.
Old Feb 15, 2011 | 09:18 PM
  #37
Rogue_Wulff
Thanks for the offer, but I'm pretty sure I have another good striker bolt somewhere in my collection of miscellanious stuff. Besides, the passenger door doesn't see much action, so the tape solution I applied could last for a good long time. Not the first time I've used this to quiet a door from rattling.
I'm always running across oddball stuff, and tend to snag whatever I think I may need, someday. Just gotta hunt thru the collection to find that striker. Pretty sure I know where it's at. Just for reference, I last needed a ford striker bolt when my ex was still carrying my son, and he's nearly 19. Yeah, I'm that old...... And so is my collection of parts.....
Old Feb 24, 2012 | 03:15 PM
  #38
BIue's Avatar
BIue
Just wanted to say thank you to thread, had no idea why my doors just started rattling. I found this thread, checked my bushing and sure enough they were gone. I bought two of these from NAPA, part# 675-5170 for a 96 Ford F150 and problem solved!!
Thank you again everyone you rock!
Old Feb 24, 2012 | 03:50 PM
  #39
Yaga1973's Avatar
Yaga1973
Elder User - What???
Been there, done that! In fact, my passenger door still has the tape on it from when I did that 10-15 years ago.
I'm actually replacing the striker assy on my driver's door. I'll get around to the passenger door when I replace all the seals on the windows. After that, I should have a rattle free cab!
Old Feb 25, 2012 | 10:45 AM
  #40
WilleyJoe.62's Avatar
WilleyJoe.62
Props and reps to you, chickade116. I just made the bushings out of PVC, and added pics to my project thread. Blessings on your house!
https://www.ford-trucks.com/forums/1...l#post11486208
Fordication
25
Sep 26, 2017 06:22 AM
JH1975
Jul 27, 2015 03:59 PM
92 Red F150
20
Feb 10, 2015 12:30 PM
hemi 27
Oct 12, 2011 09:42 PM
