Yes, they make a huge difference in how the door closes. I used to have to slam my doors, and usually the first time they never latched. The plastic around the pin really makes a difference.
Thanks Frankilin and 116, that's really good to know. I'll be glad to not have to slam anymore.
Vice grips will work or a T-50 torx bit which also will fit seat belt bolts. Just bought a socket 3/8" drive at local NAPA for about $6. Tried all the tricks I could think of 116.
Galendor,
I believe the "star" shape you are referring to is a TORX type head. Try and find the right bit to remove it or you can damage the head make it difficult to remove (do not ask me how I learned this).
Erik
'85 F150 XLT/Lariat
300-6 4sp OD trans
Galendor,
Erik
'85 F150 XLT/Lariat
300-6 4sp OD trans
Thanks EGR and Ebodel, Torx bit, got it. Er, I mean I don't have it but will buy one. No matter how many tools you have, you never seem to have them all.
If you have some plastic water pipe laying around(small flexible stuff), you can cut it and use it for a bushing also.
What wall thickness are we talking. It'd be far more cost effective for me to use your method than to try bringing in the proper bushes from the states.
I just put mine on, I used standard 1/2" inner diameter pvc pipe( looks to be about 3/32-1/8" wall thickness). I thought it might be too thick, but I had it out in the shed. I couldn't get the washer off, so I cut a slit down the lenght of the pipe about an 1/8" wide flared out at one end, stretched it with a flathead screw driver's 1/2" head, set the flared end on and slid out the driver and pushed the rest on( I guess Franklin2's suggestion of using flexline would have been better, but this is what I had). Makes a huge difference, thanks Franklin!!
I thought PVC pipe might be too brittle to use(and too thick also) but I am not against anything so long as it works ok. The stuff I used was the thinwall 1/2 flexible stuff, I think they used to call it "PEX" but after it leaked in everyone's house they re-did it and changed the name. It's the pipe that you use the barbs and the bands with the special tool.
Just the plain nylon tubing should work also. I didn't go to the trouble of taking the door piece apart. I cut the pipe to length, then slit it down the side and snapped it over the pin. It's been about a year now and it hasn't fallen off yet. No torx bits needed.
Lowes of course didn't sell individual Torx drivers. So I had to buy a little set of them which cost more $$$ than the door strikers. Oh well, now I have a torx set and can die content knowing that.
Good advice on using hardware store tubing for the bushings. I'll do that next time. But since I already bought new striker posts and a torx bit set, I'm gonna use 'em.
Question: what exactly should one "mark with a pen" before removing the old striker? Trace a tight circle on the truck surface around the washer that forms the base of the original striker before removing, I assume?
Yes, that hole where it mounts in the body is very sloppy so you can adjust the door. So you need to mark it if you don't want to mess with re-aligning it.
If after you get the bushings in place and your door is still a little hard to close, stare at the back of the door while you shut it. If it's lifting up a little bit, your hinge bushings are worn. Instead of going to the trouble of replacing the hinge bushings, I usually just loosen the hinge up front and jack the rear of the door up a little bit. But the last time I tried to do that on one of these trucks, I couldn't get to the bolts to get them loose, and broke my 1/4 universal, so I gave up and just inserted washers between the door and lower hinge mount, to push the rear of the door up. Fixed it right up.
First of all....thank you, chickade116, for posting about this; I've got rattling, hard to close doors as well, and I am looking forward to getting them fixed - they're one of the reasons my wife hates my truck.
Now...as for the striker bolts, what holds them on the back side of the door frame? My new bushings will be in today, and I'd like to fix my doors this weekend. Is there a nut back there, or some kind of clip, that I have to worry about losing? Are there any tricks to be aware of (other than marking the original position) when taking the bolts out?
the nut that the post screws into isn't exactly stationary as it moves to allow adjustment, however it does have some sort of retainer and won't drop down and become yet another thing that rattles.
