6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Coolant?
Old Feb 7, 2011 | 07:43 PM
08BLUETRUCK's Avatar
08BLUETRUCK
Coolant?
my check engine light came on while driving i noticed no difference in performance took it to the dealer to have the oil changed.this did not extinguish the light when i got home i popped the hood and noticed no coolant in the reservoir so i added some now when i start the truck it struggles yo run. can anyone tell me whats up?
Old Feb 7, 2011 | 09:34 PM
Tom's Avatar
Tom
Sorry to hear about the problem.
Needing an oil change will never set your check engine light. I'm surprised they didn't notice your low coolant level...
I'd guess you have a bad EGR cooler. This will leak coolant into your EGR system and foul your EGR valve over time. Is your truck still under warranty?
Old Feb 7, 2011 | 09:50 PM
longview1's Avatar
longview1
Banned
Or a leak?
Old Feb 7, 2011 | 09:57 PM
Tom's Avatar
Tom
Originally Posted by longview1
Or a leak?
Yeah, that's what I figured until I saw the part where his engine struggles to run.
Old Feb 8, 2011 | 05:24 AM
senix's Avatar
senix
You always want to watch your fluid levels in this motor. Weekly checks is advised. Hope you put in the ford gold coolant?
I agree, I think EGR coolers/valve are suspect now. I'd take it in rather than keep driving it. Don't want it to hydrolock on you.
Old Feb 8, 2011 | 07:25 AM
08BLUETRUCK
I did not use Ford Gold should I drain it now
Old Feb 8, 2011 | 07:40 AM
Tom's Avatar
Tom
Are you under warranty? I'd be concerned that your non-OEM spec coolant may be blamed for the failure. I'd suggest draining and refilling with Ford Premium Gold coolant before taking it to the dealer.
How many miles are on your truck?
Old Feb 8, 2011 | 07:54 AM
08BLUETRUCK
a little over 35,000 miles
Old Feb 8, 2011 | 08:39 AM
sdetweil's Avatar
sdetweil
is there anyplace other than Ford parts to get the Gold coolant?
I don't see it at AZ, Oreilly or Advance
Sam
Old Feb 8, 2011 | 08:52 AM
senix's Avatar
senix
Sam
I have gotten mine at Napa.
Old Feb 8, 2011 | 09:53 AM
cmalinowski's Avatar
cmalinowski
So they got into your truck to move it to change the oil, noticed the check engine light and didn't do anything about it? They didn't take two seconds to hook up an OBD scanner and look? Didn't ask you about it?
Wow.
Old Feb 8, 2011 | 06:36 PM
cheezit's Avatar
cheezit
Wow.
the guy changing your oil is in no way qualified to diag a check engine light on anything, If he was he would not be changing oil. Simply hooking up a scan tool doesnt really tell someone much. Its not as simple I have X code then it must be X problem. I wish life was that simple.
Now back to the OP. if you suspect its an egr cooler failed. do not start or drive the truck. Thats the fastist way to bend #8 rod.
fd3s_rx7
Jun 2, 2012 01:50 PM
orange powerstroke
Sep 22, 2011 01:41 AM
Big Dually
Feb 15, 2011 08:47 PM
02GrayPowerStroke
Mar 5, 2010 03:52 PM
groundrat
Modular V10 (6.8l)
Sep 14, 2009 08:39 PM
