Black sluggish oil in Degas Bottle - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Reload this Page >
Old 06-02-2012, 12:22 AM
fd3s_rx7
fd3s_rx7 is offline
fd3s_rx7 is starting off with a positive reputation.
Ok so I've replaced the degas bottle/ coolant flush/ and new 16 psi cab.
Very minor coolant puking out of the cap and when it's fully warmed I can see hot steam coming out of the cap. There's also noticable black oil or whatever that gunk is in the degas bottle. The truck seems to still run fine. Just coolant lightly puking out of the cap and black sluggish gunk in the bottle. Not sure if its oil...
What is the issue? and how much am I looking to spend?
Old 06-02-2012, 12:32 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
your oil cooler popped DO NOT START OR DRIVE IT or end result would be catastropic failure and shortblock time
If you do it will only get worse and trust me thats a huge job getting that dog and pony show turned around lots of coolant flushing with simple green cleaner and maybe vc-9 towards the end
Its making a paste like substance in cooling system and the water pump dont pump Paste
IIRC its around 1500.00-1800.00 to change oil cooler and egr cooler and this might be on the low side of things. I changed all that went egr deleate though and was in it 1000.00 with parts and new fluids
Sorrey its not better news
It may have blown the Headgasket already with the puke
pull egr valve and hope its wet cuz the alternative might be HG
1973dieselhighboy's Avatar
1973dieselhighboy
1973dieselhighboy is offline
1973dieselhighboy is starting off with a positive reputation.
sounds like to me you have a oil cooler that has failed if it is oil, and i would fix it now since it is just in the degas bottle will be easy now to flush instead of down the road if it mixes with the coolant and makes a think goopy crap
if you do it yourself about 500 if a dealer or shop i would guess probably around 1500
Old 06-02-2012, 12:52 AM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I agree the sooner he takes care of it the easier it will flush out
But Its already contaminated the whole system
The coolant leaves Oil Cooler and goes to EGR Cooler so EGR Cooler is Plugged up with that junk too so IMO he needs a new egr cooler to unless he has a egr deleate
If the egr cooler hasnt failed yet its on Borrowed time
It may flush clean IDK Kinda high risk IMO
Old 06-02-2012, 12:57 AM
1973dieselhighboy
yes very true and at the price for a new egr cooler its better to fork out just a bit more cash and get a good delete or a bulletproof cooler
Old 06-02-2012, 01:50 PM
egregg57's Avatar
egregg57
egregg57 is offline
egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.
Blade said it. Get it off the road before you have an astronomical repair in front of you!
dtwillie
09-19-2016 02:40 AM
6.0lbross
04-10-2016 11:22 AM
rybike13
6.4L Power Stroke Diesel
02-08-2016 08:23 AM
jlillie
01-22-2016 12:51 PM
Kdawg89
09-26-2015 09:31 PM
Quick Reply: Black sluggish oil in Degas Bottle
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
