little help
Old Feb 7, 2011 | 01:12 PM
92nite351's Avatar
92nite351
little help
can i eliminate these two hoses that run parralell to the engine? they connect to this
will this effect my CEL or mileage.
Old Feb 7, 2011 | 03:26 PM
92nite351's Avatar
92nite351
do i need to provide more info...it looks like its part of the smog pump or something
Old Feb 7, 2011 | 04:28 PM
jas88's Avatar
jas88
Your pictures are a bit confusing. The metal hoses in the first pic go from the air pump to the catalytic converter. Those are the "output" hoses. The muffler in the second pic is also part of the air pump system, but it's for the intake. So it connects to the air pump, but not to the metal lines you show in the first pic.
I cannot comment on what it will do to mileage if you disconect them, but if you plan to do so, you will need to remove the entire system as it's tied into the exhaust, and after a while you will have a major exhaust leak.
Old Feb 7, 2011 | 04:34 PM
92nite351's Avatar
92nite351
k thanks. the point is that its a pita to change my plugs cuz of those metal lines and hoses. it got frustrating cuz they have no space to move around to get at the plugs.
Old Feb 8, 2011 | 03:48 AM
TexasGuy001's Avatar
TexasGuy001
That looks like the same thing that was recently discussed here.
https://www.ford-trucks.com/forums/1...cumn-line.html
tasboj
19
Jan 21, 2013 07:28 PM
hammerhead90
32
Aug 28, 2011 12:40 AM
fordpride
Jul 28, 2011 12:07 PM
YellowSled
Oct 3, 2010 12:20 PM
RicManSr
Jul 1, 2009 04:00 PM
