Pulley problem
Old Feb 7, 2011 | 11:50 AM
redman84's Avatar
redman84
Pulley problem
I noticed today that my tensioner pulley is not flush with the rest of the pulleys anymore. I went to just check my fluids and saw that about 2 or 3 ribs of the belt were off of the alternator pulley. If you're looking down at it from the top, the right (drivers) side is closer to the fan than the bracket that the pulley rotates on. I put the breaker bar on the fix my belt and the pulley bracket was rubbing pretty good making it hard to move. The bearings feel good. There's no play, just smooth rotation. Any ideas on what happened and what I need to do?
Old Feb 7, 2011 | 11:56 AM
Midwest Dually's Avatar
Midwest Dually
Thats unusual.. When you put the belt back on properly, did the tensioner move inward or outward at all when you took the stress of the belt off? I would assume all the other pulley bracket bolts are on snug for the other drive items?
Old Feb 7, 2011 | 01:08 PM
tbone heller's Avatar
tbone heller
Sounds like you need a new tensioner & belt.
Old Feb 7, 2011 | 01:12 PM
Robbgt's Avatar
Robbgt
Gates - 38119 - tensioner. Available at rockauto or amazon (just got one from amazon, $50ish shipped)
Belt: goodyear gatorback, can get at advance and autozone. maybe napa too?
https://www.ford-trucks.com/forums/1...-fan-belt.html
Old Feb 7, 2011 | 03:21 PM
redman84's Avatar
redman84
That definitely looks like it will do the trick. Does that whole assembly pictured come as a whole? And what size torx head is holding it in?
Old Feb 7, 2011 | 03:57 PM
pjwoolw's Avatar
pjwoolw
Pop the seal on the new bearing on the pulley and put some good synthetic wheel bearing grease in there. The bearings are mostly made in China and will fail quickly with the grease used during manufacture. In fact I'd repack all the pulley bearings since the belt is off anyway.
Old Feb 7, 2011 | 03:59 PM
pjwoolw's Avatar
pjwoolw
Oops! T47 I believe. I hate those things.
Old Feb 7, 2011 | 04:13 PM
Hussler's Avatar
Hussler
IIRC it's a T70. A few weeks ago I was in there a could not break the Torx loose on the adjuster although I did get the idler off for replacement.
Old Feb 7, 2011 | 04:24 PM
pjwoolw's Avatar
pjwoolw
I replaced all the bearings in the almost new pulley and tensioner last week. They were a T47 bit. I did the Superduty conversion on the tensioner but I don't recall that there was a difference. Possible I suppose. I still hate those things!
Old Feb 7, 2011 | 04:32 PM
Hussler's Avatar
Hussler
You probably are correct.
I'll check when I get home and I agree they are a real pain. One slip and you have some busted knuckles and probably a stripped torx head. Don't know what brilliant engineer came up with that configeration.
Old Feb 7, 2011 | 04:39 PM
pjwoolw's Avatar
pjwoolw
I have to use the 3/8" breaker bar to break them loose.
Old Feb 7, 2011 | 05:06 PM
Robbgt's Avatar
Robbgt
This is what's in the box, notice no bolt. Still haven't installed mine as you can see (way to cold out), hoping that I can re-use the stock torx on it...
ALSO this is the new UPDATED tensioner, so it will have a longer arm than your stocker, look here
https://www.ford-trucks.com/forums/1...n-changed.html
Old Feb 7, 2011 | 05:30 PM
pjwoolw's Avatar
pjwoolw
The same POS Torx head bolt will work. I just couldn't put that thing on my rig. I'm sure it works just fine. I didn't like the look of it.
Put a little anti seize on that bolt before installation.
Old Feb 7, 2011 | 06:34 PM
Hussler's Avatar
Hussler
Checked and the one I purchased was the T50. Maybe the T47 is correct .. anyone know for sure?
Old Feb 7, 2011 | 07:02 PM
pjwoolw's Avatar
pjwoolw
I'm looking at both right now and I can't see any physical difference between the two. Granted these are Lisle sockets so who knows. T50 is probably the correct size. Alldata says it's a 16mm. I'll check the service manual.
