WOR-053020 Windsor Sr. cast iron
intake runner volume - 200cc
valve dimensions - 2.020" x 1.600"
chamber volume type - 64cc fast-burn
spring diameter - 1.250"
cam type - hydraulic
Log on to the World Products (world castings) website and you can get more detail on cam sizes allowed with supplied springs and recommended installation items.
I running a set of the Sr. aluminums on my 351W (stroker393) with a crane h-238 hyd. flat tappet (536 / 560 lift), Weisco pro-tru flat top pistons and eagle h-beam rods and the torque is unreal. Used the heads right out of the box with no alterations with FMS 1.6 roller rockers. My final compression ratio is around 10:8.1.
