bad battery??
Old Mar 2, 2011 | 08:49 PM
  #46
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
11.1 in start, but it just clicks quickly and won't turn over?
13V sitting is okay but with only 13V and the engine running at idle, I personally don't think the alternator is up to snuff.
This shows the alternator is doing -nothing- at idle, or the regulator is bad.
My battery sits at 13.27V engine off and 14.65 while charging. (I do have a 130A 3G alternator though)
Old Mar 2, 2011 | 09:49 PM
  #47
79F-1504x4's Avatar
79F-1504x4
It doesn't start lol. That's the problem. Plenty of voltage at batt and both sides of solenoid, but no response from the starter. Which tested good three days ago.
With a jump it will make a half *** effort to crank. Like a slow 1/4 turn. That's it. Hasn't ran in three weeks.
Old Mar 2, 2011 | 09:57 PM
  #48
fellro86's Avatar
fellro86
Keep in mind that bench testing a starter doesn't always catch a bad one, as there is no load...
Old Mar 2, 2011 | 10:37 PM
  #49
79F-1504x4's Avatar
79F-1504x4
Yeah it wouldn't be the first time autozone has screwed me lol.
Old Mar 3, 2011 | 06:16 AM
  #50
fellro86's Avatar
fellro86
It isn't the people, the machine just can't test for a load when it just free spins. You can do similar by hooking it up to a boost charger and spin it that way, but it can't tell you what it does under a load. If the rear bushing or front bushing are bad, it can still free spin ok, but as soon as it has a load on it, the shaft gets pushed sideways, and will crash into the magnets or windings.
Old Mar 3, 2011 | 07:35 AM
  #51
bashby's Avatar
bashby
I dont know that we have ever got around to checking the ground. Quick, easy check. Put one voltmeter lead on B- and one on the engine block. Read the voltage WHILE CRANKING OR TRYING TO CRANK. This will tell you the voltage drop of your ground circuit, it should be 1v or less.
Old Mar 3, 2011 | 12:31 PM
  #52
79F-1504x4's Avatar
79F-1504x4
I replaced the ground cable but I will double check it when my brother gets here later.
Also plan to double check voltage at starter.
Old Mar 3, 2011 | 12:38 PM
  #53
deeznuts822's Avatar
deeznuts822
I would change out the starter to at least a different one if not new. You have enough power to turn it so if you can spin it by hand then that starter has to be crap!
Old Mar 3, 2011 | 01:53 PM
  #54
bashby's Avatar
bashby
Originally Posted by 79F-1504x4
13v at the batt when idle.
good plan.
oldiron
Electrical Systems/Wiring
13
Oct 6, 2012 10:18 AM
oldiron
Sep 30, 2012 08:30 PM
Slankky
Aug 19, 2012 02:02 PM
SixOhCrew
All Things Towing
Feb 16, 2011 06:40 PM
HeeHaw78
Dec 20, 2010 03:01 AM
