bad battery??
Old Mar 1, 2011 | 02:01 PM
  #31
bashby's Avatar
bashby
I guess if its a MT you can always park on a hill and bump start it. Or you could check voltage to the starter while cranking. If you're willing to do some checks with the voltmeter I can try to walk you through it again.
Old Mar 1, 2011 | 02:19 PM
  #32
79F-1504x4's Avatar
79F-1504x4
When I checked at the starter I got 2v and it climbed to 8v if my brother held the key probably still not enough right?
Bump starting isn't really an option since it jas a new carb and dizzy and doesn't run well untuned lol.
Old Mar 1, 2011 | 02:23 PM
  #33
bashby's Avatar
bashby
Originally Posted by bashby
If you have 10v at the solenoid end of the cable while cranking and 2 at the starter end you have a bad cable. When you're checking at the starter if you are touching the stud on the starter and not the end of the cable it could be a bad connection at the starter, you need to test at the cable itself.
Like I said earlier.
Old Mar 1, 2011 | 02:44 PM
  #34
79F-1504x4's Avatar
79F-1504x4
Yep and I'm not sure where I checked it but I need a helper lol
Old Mar 1, 2011 | 02:49 PM
  #35
bashby's Avatar
bashby
Makes it difficult with one person. If you're pretty sure that you had a good connection with the meter when you did that test, clean up the connection at the starter and try to start it. If still no crank get a new cable for it. Radio shack should have aligator clips for you voltmeter if you want to retest.
Old Mar 1, 2011 | 03:05 PM
  #36
79F-1504x4's Avatar
79F-1504x4
Damn good idea I have aligator clips lol. Ill try it out tomorrow
Old Mar 1, 2011 | 06:40 PM
  #37
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sounds VERY familiar......
I'm changing the cable.
subscribed
Old Mar 2, 2011 | 06:42 PM
  #38
79F-1504x4's Avatar
79F-1504x4
Update!
Installed a new starter cable today, hopped in the truck and hit the key. Solenoid went crazy clicking.. no crank. Held starter cable to battery, no crank no noise. Jumped truck, cranked slowly. Waited ten mins on cables, cranked slowly.
Also my brother said his lights an heater went nuts when I crankes my truck...
Ideas? Besides the scrapyard?
Old Mar 2, 2011 | 07:09 PM
  #39
ctubutis's Avatar
ctubutis
The solenoid clicking generally indicates low voltage present....
Old Mar 2, 2011 | 07:18 PM
  #40
bashby's Avatar
bashby
Check battery voltage while trying to crank it.
Old Mar 2, 2011 | 07:24 PM
  #41
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My truck is starting fine now.
The cable had worn through its insulation on the crossmember.
I was trying to dump current through the frame every time I engaged the solenoid.
Old Mar 2, 2011 | 07:25 PM
  #42
79F-1504x4's Avatar
79F-1504x4
13v at the batt when idle.
Old Mar 2, 2011 | 07:28 PM
  #43
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
How much when revved to 2500 or so?
How much engine off?
How much while cranking?
Old Mar 2, 2011 | 07:37 PM
  #44
ctubutis's Avatar
ctubutis
Exactly, especially while cranking.
I will quote this again as it's key to finding the problem:
Most don't seem to understand just reading a battery sitting there will tell you pretty much nothing, unless it has a dead cell. Reading the voltage at the battery, and different spots along the circuit path with a load on the battery and the circuit will tell the story.
Old Mar 2, 2011 | 08:28 PM
  #45
79F-1504x4's Avatar
79F-1504x4
Voltage at the batt sitting was 13. Cranking was 11.1. I ran out of time to check it at the starter again.
