6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 HPFP Ups and Downs
Old Feb 6, 2011 | 11:52 AM
turbohunter's Avatar
turbohunter
How about a thread on the Ford/Int. high pressure fuel pump on these engines.
There seems to be a lot of info/misinfo out there on these pumps that SEEM to be a bit delicate.
My thirst for info on these deals came about when mine failed at 38k.
I admittedly know little about them as I have only seen mine apart at a dealer and talked to the mechanics about them.
I am a Fordoholic and just want info.
I change my filters every 10k and oil every 4 to 5k.
Also use an additive 4 out of 5 tanks of fuel.
Are they indeed delicate?
Can they be made more solid if so?
Thanks in advance for the info.
Old Feb 6, 2011 | 05:48 PM
senix's Avatar
senix
I think the issue really is they dont tolerate water or bio-fuel well. I think this is because of the way they maintain there lubricity.
couple that with the close tolerances and there is no margin of error.
Old Feb 6, 2011 | 07:55 PM
wp6529's Avatar
wp6529
The HPFP operates up to 26,000 PSI pumping fluid with mediocre lubricity (ULSD), this is no easy feat. Anything the reduces the already poor lubricity such as bad fuel, water getting to the HPFP, air getting to the HPFP or the like has a high probability of damaging the pump.
Given the high stresses the pump sees in normal operation, once it's damaged the damage will just snowball to rapid failure. It's critical to maintain the filters meticulously using only the revised FD4617 filters which reduce the risk of water getting past the HFCM filter and always use a fuel additive that will add some lubricity to the ULSD.
Old Feb 6, 2011 | 08:09 PM
Larry NCKS's Avatar
Larry NCKS
Bio fuel in itself is a lubricant. My suggestion - Yes, once again - buy premium diesel fuel and nix the additives.
Old Feb 7, 2011 | 12:22 PM
turbohunter
Premium fuel is a must, agreed.
But why nix the additives? Isn't helping the cetane level and lubricity helpful?
Old Feb 7, 2011 | 10:10 PM
wp6529's Avatar
wp6529
Yes, helping cetane and lubricity is helpful. The previous poster was noting that bio-diesel has relatively good lubricity, which it true, however bio-diesel has some downsides, particularly homebrew bio-diesel which may not be well refined and filtered.
The Bosch piezo fuel injectors are reported to not be very tolerant of bio-diesel, and if you have engine problems and Ford finds more than 5% biodiesel in your tank they can deny a warranty claim.
The additives such as the Ford branded additives and the Stanadyne Performance Formula additive (Stanadyne is reported to OEM the Ford additive) increase lubricite without the risks of bio-diesel. The proper additives are also known to notably increase the intervals between DPF regens which is also a significant benefit.
Old Feb 8, 2011 | 02:25 AM
Larry NCKS's Avatar
Larry NCKS
A true premium diesel has all the lubricity and Cetane number that it needs.
I did a study for my dealer early on in my days with the 6.4. He had me run Motorcraft Cetane boost through 5 tanks of fuel and record my findings on fuel economy, etc. The results, using Cenex Roadmaster XL premium fuel - no noticeable difference in mileage or performance.
Old Feb 8, 2011 | 07:44 AM
Tom's Avatar
Tom
I'm pretty confident that Siemens manufactured the fuel systems in these trucks...
Originally Posted by Diesel Power Magazine
The 6.4L Power Stroke eliminated the HEUI system and went to a Siemens common-rail piezo injector that used no engine oil
From HERE.
Old Feb 8, 2011 | 11:31 AM
turbohunter
I did the same study just for myself ( using Stanadyne ) and found that while mileage increase was minimal, it did increase the distance between burns from 140ish to over 200.
I would have thought it would show up more in my mileage calcs but only found a less than 10% increase.
I'm still happy to reduce the regens as much as possible. It can't be good at all for the health ( longevity ) of the engine to be subjected to that heat.
Hey Crazy
Is there a diagram ( maybe an exploded view ) of any sort for the HPFP?
I've done a quick search and found nothing.
Thanks again guys for the info
Old Feb 8, 2011 | 11:36 AM
turbohunter
Whoa
Just saw the article you linked Crazy
Should be required reading for every 6.4 owner
Thanks
Old Feb 8, 2011 | 06:23 PM
Tom's Avatar
Tom
Hey Crazy
This is the best I can come up with, hopefully it's what you're looking for.
You can find this in the tech folder under the "6.4L Bible" link. This particular one came from the "Air Management System" link within that page.
Old Feb 8, 2011 | 07:01 PM
senix's Avatar
senix
here is an overall one
Old Feb 8, 2011 | 10:18 PM
turbohunter
Now it's making sense about lubricity, cavitation, lubrication and the like making a big difference in how it runs.
It's a complicated little piece of hardware.
Thanks guys, the visuals help a lot.
Old Feb 9, 2011 | 11:21 AM
wp6529's Avatar
wp6529
Complicated and operating at very high pressures. Common hydraulic pumps run at 2,500-3,000 PSI, even the big machines run 4,500-5,000 PSI. The HPFP in our trucks has a lot more in common with the pumps in waterjet cutters.
Old Feb 9, 2011 | 11:49 AM
powerskull's Avatar
powerskull
Would a system like the FASS help out at all. i have hard on other sites about lift pumps. what can you add to help in extending or protecting the fuel system namely the HPFP?
