6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 HPFP Ups and Downs
Old Feb 9, 2011 | 03:00 PM
wp6529's Avatar
wp6529
Originally Posted by powerskull
Would a system like the FASS help out at all. i have hard on other sites about lift pumps. what can you add to help in extending or protecting the fuel system namely the HPFP?
I'm not sure how much something like that would help. I don't think it would hurt, however I do think it would be a possible target if Ford was looking to deny a warranty claim, so you have to take that into consideration.
What I think would help, and would be relatively inexpensive is to install a pressure gauge in the fuel line past the HFCM with a display in the cab. The pressure should be low enough to use an ordinary oil pressure sender and gauge pair.
By noting the normal fuel charge pressure heading to the engine HPFP you should be able to identify if the pressure is dropping due to HFCM filter clogging, air or the like and hopefully head off any problems.
Old Feb 9, 2011 | 05:48 PM
turbohunter's Avatar
turbohunter
I asked the Ford mechanics point blank (while mine was down for the pump) if using a FASS or Air Dog would affect my warrantee.
They said "yes, just use an additive".
I know there is some question about it. Just saying what they told me.
The common sense part of my brain tells me if you can't get consistent quality fuel then you do what you have to.
If you live where I do and it's readily available then use it ( pay for it ).
Old Feb 9, 2011 | 08:11 PM
Tom's Avatar
Tom
Good thought, but I don't think it would work well. These fuel systems operate at a much lower pressure than expected for an oil pressure sending unit. Only 3 PSI!
I don't now what could accurately determine pressure within that range.
Old Feb 10, 2011 | 12:24 PM
wp6529's Avatar
wp6529
There are certainly pressure sensors that will accurately measure low pressures, but I guess 3 PSI rules out stuff you can find cheap at your local auto parts store.
Stray Current
Oct 31, 2017 07:54 PM
Betty Cress Bishop
New Member Introductions
Mar 24, 2017 02:29 PM
Kingkong0192
Dec 18, 2016 03:06 PM
Claudia Tull
6.7L Power Stroke Diesel
Sep 13, 2016 09:32 AM
Ranger1972
Dec 16, 2015 12:20 PM
