Sponsored by: Real Truck
Front end leveling questions
Old Feb 6, 2011 | 11:38 AM
ride_relax's Avatar
ride_relax
Hey guys I have a 03 f350 and want to level the front end I googled it and seen a short spring stack 2.5 in for like $131.00 is that good deal or what do I need to do this the right way? And help is greatly appreciated
Old Feb 6, 2011 | 02:34 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
I have a 2 1/2" Tuff country leveling kit on my truck.It came with an adjustable drop track bar bracket,u-bolts,spring packs[$275-$300].Some of the cheaper kits have really short springs and no drop bracket.It rides a little rougher,but is great when I have my snowplow on.They also make spring hanger bracket lift kits.They keep the factory ride.
Old Feb 6, 2011 | 03:08 PM
ride_relax's Avatar
ride_relax
Some ppl say that they didn't need to do anything with the track bar... Is this true ? I'm not sure thats why I ask u guys lol
Old Feb 6, 2011 | 04:30 PM
nogo73's Avatar
nogo73
you dont need to but don't expect the same ride quality.
Old Feb 6, 2011 | 04:58 PM
mnpowerstroke99duty
Ideally, you want the track bar and the drag link parallel to one another.With the drop bracket they stay parallel.Not to say, it won't be ok without it though.
Old Feb 6, 2011 | 05:16 PM
Grumpy Moose's Avatar
Grumpy Moose
Yea, those are the trucks you follow behind on the highway and notice their front and rear wheels don't line up in the same track. Though I doubt the resulting offset would be that noticeable on a 2.5" lift, probably only 1/2" or so. But on a big lift it will make quite a difference.
Old Feb 6, 2011 | 05:34 PM
DAVE67FD's Avatar
DAVE67FD
Not installing a track bar drop bracket or adjustable bar will increase bumpsteer and will cause your truck to wander and not track straight. This can also lead to premature wearing of your front end parts like tires, ball joints, tie-rod ends etc..
Spend the money to do it correctly and make sure you have a quality alignment done afterwards, and i dont mean just a toe-in and steering wheel adjustment.
Old Feb 6, 2011 | 06:16 PM
mnpowerstroke99duty
It took 2 new camber/caster adjusters to correct my steering and a very good alignment shop.It drives down the road better than when new.I agree most alignment shops set the toe and don't even check or adjust the caster/camber.
Old Feb 6, 2011 | 08:19 PM
Mr-Pipeline's Avatar
Mr-Pipeline
I just completed a leveling kit install on my 2000 F350. The Zone Off-Road kit comes with an adjustable track bar, check it out.
https://www.ford-trucks.com/forums/1...-pictures.html
scorpion48
Oct 31, 2012 09:54 PM
KIDkiser
Jul 1, 2011 04:51 PM
cschannuth
Feb 21, 2008 08:55 AM
doctor_ratz
Nov 8, 2007 05:42 AM
