I have a Ford Excursion and I am in desprate need of new tires. I currently have 305/75/16 tires with a 6" lift the tires are too small. I have not found too many tires is the sizze I want in load range e does any have any experience with Nitto Dune Grappler in snow, rain and sand. Or any other reccomendation.
General Grabber AT2's! Great tire, great price, and awesome in the snow! I have had them on two of my trucks. They will be going on my new F250 as well. Save and Buy Tires Direct @ TiresDirect.Net
Here is a really good place to buy them! you won't be sorry!
just a heads up, After working at one of the west coast's largert tire dealers for 6 years, I can tell you that a "D" rated tire with do anything you ask it to do with youe excursion. There is less then a 300lb rating per tire, I have put probably hundereds of sets of D tires on 3/4 and 1 ton trucks with no negative effects. Good luck to you
You still wouldn't have to worry about a thing. The only reason you would truly need an e rated tire would be if you had a truck with a camper on it. Or you were doing hardcore off roading. however if that is what you want here is the best I can find for you. I just sold My F150 and I had 295/65R18 Goodyear Duratracs on it. AWESOME TIRE! This is the answer you are looking for.
