Bad FICM cause alternator Problems?
Old Feb 6, 2011 | 08:24 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Unhappy Bad FICM cause alternator Problems?
Hey All!
Spent a lot of time in the SD Tech Folder yesterday and I'm going to check my FICM this morning. I have the exact cold start issues everyone was talkin about. On top of that, I can't keep an alternator in my truck. I get an intermittent battery light after 10 miles or so and it goes on and off randomly after that. Batteries load check good, cables clean and tight etc. I've replaced the alternator twice in the last 6 months (since I got the truck) and over the holidays I pulled the alternator and took it to a good repair shop. They said they replaced the diode plate. Think the power draw from a bad FICM could take out the diode plate?
Oh yea, 2006 F250 6.0 Diesel. (still trying to get the hang of this new "internet" thingie!??)
Old Feb 6, 2011 | 03:11 PM
Rusty Axlerod
well, there goes that idea. did the FICM test and had:
Key on engine off - 48.4v
Buzzer off - 47.9v
Start - 48.5v
Guess thats not the problem.
Old Feb 6, 2011 | 03:47 PM
powerstroke72's Avatar
powerstroke72
Welcome to FTE Rusty! I'm going to move your thread to the 6.0L Powerstroke Diesel forum where you should be able to get some help with your issue.
Old Feb 6, 2011 | 04:54 PM
Rusty Axlerod
thanks John!
Old Feb 6, 2011 | 04:55 PM
powerstroke72
<fillllllllllllllll>
Old Feb 10, 2011 | 09:44 AM
Rusty Axlerod
Update. After alternator repair for the second time, decided to test batteries "one more time" and the passenger side failed load test! This battery had been check four times previously and passed each time. I'll see in a few weeks if it is truly fixed this time.
Old Feb 10, 2011 | 10:55 AM
davidkstyler's Avatar
davidkstyler
It is usually recommended to replace the batteries in pairs so that they balance the charge. How old are they?
Old Feb 10, 2011 | 11:03 AM
LOOnatic's Avatar
LOOnatic
Yep, go ahead and change both.
At least its cheaper than replacing, fixing a bad FICM like i have to do
Old Feb 10, 2011 | 11:10 AM
ljutic ss's Avatar
ljutic ss
Originally Posted by Rusty Axelrod
Hey All!
Oh yea, 2006 F250 6.0 Diesel. (still trying to get the hang of this new "internet" thingy!??)
The answer is a faulty alternator can lead to problems with the FICM once the voltage from the batteries drop.
Old Feb 10, 2011 | 11:40 AM
Rusty Axlerod
They were stickered as 8/08. Dropped in a new pair of Duralast gold tops ($265) and the alt with new diodes/plate/regulator. Seemed to run noticably better and gas mileage was up a couple of MPG's as a bonus. Only 40 miles or so on it so far though, I'm not gonna be completely satisified until it goes a couple of months with no battery light.
Old Feb 10, 2011 | 11:52 AM
Rusty Axlerod
I guess the odd thing about this problem is the bad battery checked good several different times before I caught it. The batt light was on when I shut down the truck the last time-maybe that's why it showed bad. I've heard of plates warping or bad terminal connections inside the case. But I never had on go bad intermittently like that before.
Old Feb 10, 2011 | 06:21 PM
cheezit's Avatar
cheezit
finding aremain alternatorsd that are worth a the money are hard to do. that is one of the worst reman parts out there.
Old Feb 10, 2011 | 06:30 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by cheezit
finding reman alternators that are worth the money are hard to do. that is one of the worst reman parts out there.
You got that right, and IMHO motorcraft remaned alternators are one of the worst. They last just long enough to get out of warranty (13 months maybe) which makes the lifetime warranty parts the way to go (sometimes).
Nevadahunter1
May 3, 2017 05:17 AM
command37
Jan 9, 2016 09:36 AM
Jmoen7
Dec 27, 2015 03:00 PM
mck99f250
Jun 15, 2011 07:38 PM
rcain1
May 5, 2004 07:48 PM
