I would stay away from hella. I have had a few and the outer ring around the glass will shake the 4 little allen head bolts loose and cause a lot of problems. Then when you try and get parts from hella they have no idea where to find them. KC's are good, tough, pretty cheap, and are easy to get help for (america rocks).
Lightforce's are Australian.
Piaa also makes some good lights. But i would recommend kc's.
Thats cool. High powered off road lights can be very useful. I had some for a while. I was just getting at what the OP was wanting something he can use on the road.
I hate people that drive with any type of aux lights on. usually way too bright anyways. Just my two cents.
But understand in foul weather. I'm just talking about 24/7.
It has to do a lot with aiming the lights, and not so much with their power - for instance I have some small 55W driving lights on the very bottom of my bumper, that are aimed so they are long-distance lights, them suckers will probably blind the heck out of an oncoming driver. Right next to those, again pretty much barely a foot above the road surface, I have some small floods, also 55W, those are aimed so they light up the road immediately in front and slightly to the side of the truck (where the factory headlights miss big time), the only way those blind someone is if said someone is laying on the pavement, in which case they should be more concerned with getting out of the way of the almost 5 tons of steel that are my truck, lol. I could have gone with actual driving lights instead of the floods, but they are usually designed to out-reach the factory headlights, which I do not really need at all. The flood lights are on together with the parking lights, while the long-rangers get used maybe twice a month, if that, for spotting deer and stranded vehicles on the side of the road. I've had that setup for several years now, I'm yet to get hi-flashed cause I blinded someone...
Angle makes perfect sense. I have four spots up front. I point two straight and two to the sides of the road. I use them on country roads when I can't see any headlights.
You are actually responsible with your lights. The worst is the little pokemon cars with their JDM autozone lights in the bumper. Haha.
My friend had aircraft landing lights. They are very similar to the higher powered KC Daylighters. Still not legal for on road use.
I feel somewhat the same way about people running auxilary lights all the time. I don't care about factory fog lights except for the Avalanche type fog lights. Those things glare.
My Hella 550 lights don't glare at all. They have a bulb cover so you can't see the light coming from the bulb itself.
