Fuel pipe problems
Old Feb 5, 2011 | 11:06 AM
4CFarms's Avatar
4CFarms
Fuel pipe problems
Is there anything i can do to keep my front tank from foaming over whenever i fill it. The pipe goes down 45 deg and then goes flat. IS there anything that will help it flow better so i dont waste so much diesel?
Old Feb 5, 2011 | 05:24 PM
14psd's Avatar
14psd
it sounds like your filler is being smashed. It shouldn't be that way. The front tank is not hard to drop at all. I have done it several times when I ran WVO. I had to put in a new tank recently also (another story PM me if you want details). But two bolts, one hose clamp at the tank, and the vent tube and the tank will come down so you can unscrew the feed tube. Then you can look more closely at the filler tube and find out why you're having the foaming problem. Ten minutes and you should have that tank out. I believe the bolts are 14 or 15 mm. There should be a tube inside the rubber hose that is longer than the rubber on also. The rubber one is to allow air to escape and not have that foaming issue. I hope this helps.
Old Feb 5, 2011 | 06:51 PM
pjwoolw's Avatar
pjwoolw
Slower is faster when pumping diesel fuel. Every diesel I've ever had will foam up once the tank has two or three gallons or so to go until its full. Just find the super slow spot on the nozzle through trial and error and top off. If a pump is turned up high like a gasoline pump I always complain until they slow it down.
Is your front tank harder to fill than the rear? If so there may be a problem. If not I'd say its normal.
Old Feb 5, 2011 | 06:57 PM
4CFarms's Avatar
4CFarms
ya, the back doesnt have that problem. but when u say it is smashed, how would you fix that? new pipe or what?
Old Feb 5, 2011 | 08:37 PM
pjwoolw's Avatar
pjwoolw
If you were willing to spend the money these folks have a real good product.
Old Feb 5, 2011 | 09:49 PM
4CFarms's Avatar
4CFarms
ya didnt want to spend that much on it preferably
Aaron M Sholley
24
Jan 8, 2014 07:47 AM
vwhed1979
Aerostar
Feb 10, 2012 09:58 PM
jtownes14
17
May 21, 2008 03:16 AM
john day hardy
27
Oct 22, 2005 08:24 AM
JackFeist
Nov 22, 2002 08:37 AM
