Chassis/frame extension
Old Feb 7, 2011 | 11:52 PM
vintage56's Avatar
vintage56
one other thing that I don't think has been mentioned is cutting a zag in the splice. a lot of guys make the frame cut in a Z. in other words, a cut down from the top thru the top flange and into the web of the C channel frame, then near the middle of the web, the cut jogs fore or aft, then jogs vertical again down thru the lower flange.
JML
Old Feb 8, 2011 | 01:01 AM
old_dan's Avatar
old_dan
The huck bolts/rivets are more or less outdated in the aviation industry in favor of fasteners that require less tooling. You could go for some Hi-Lok rivets....those are pin rivets that you fit into a reamed hole. They are finished off by screwing on a nut that has a shear collar...so you tighten until the hex head breaks off. You get perfect pre-load, but they can be spendy. I think you'd be OK with a bunch of grade 8 bolts that are properly torqued.
Here's a link for Hi-Lok fasteners: http://www.gen-aircraft-hardware.com.../pdf/hilok.pdf
Dan
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
May 9, 2017 02:39 PM
Torklift Sheryl
Dec 8, 2016 06:26 PM
3twinridges
Nov 2, 2016 06:14 PM
sprintnut
May 10, 2010 04:25 PM
mtfrdlvr
Exhaust Systems
Dec 4, 2007 02:29 AM
